[Audi A3/S3] wheel spin
s3ollie
while pulling away from a junction today gave it a bit of stick and i got quite a lot of wheels spin. my car is a 1999 s3 210bhp and as i understand it, it has traction control? am i right?
so this should stop wheel spin right?
My mate with a TT say he's always getting his traction light in the dash on when we go for a drive following one another, but i never do as far as i can tell, driving the same pace!
all lights go out from the dash on start up so i assume all is ok as it runs self checks.
Wasn't even an option on my '99 version.
Are you sure your car is still 4WD?? My S3 had a fuse blow - left me in 2WD only - which came as a bit of a shock when I put my foot down on a wet roundabout and understeered towards the kerb!!
Sidicks
mines a 02, with ESP, and with ESP most defintely on i used to get plenty of front wheel spin even at very low speeds - reason, seriously bald tyres!
New tyres, no spin whatsoever, infact did a 0-60 test the other night with my mate from standing start. Floored it and it sort of just seemed to sit thier not moving, then the grip kicked in and we were off.. no spin at all.. and a 6.7 time, which i was quite pleased with for a non chipped S on a first attempt smile.gif
same experience here..worn tyres/low grip surface
other option though is a blown Haldex controller - but you would expect a warning light - mine the ESP warning came on, and stayed on, first time it was called for.
im not sure if it has esp i thought so (cant turn it on and off, no switch on dash) but if it was an option it may not have it. tyre need chagings soon on the front but not for a while so dont think its that. how do i check if it has it or not also how do i check the haldex?
ran vagcom a while ago and nothing can up to do with any of this cheers
I think if you got ESP you should have a switch, whether the earlier ones were like this i dont know.
To test Haldex, easiest way is see how the car copes with a few brisk acceleration runs on a straight quiet road.
before you start hook the handbrake up one notch, just enough to bring on the handbrake light, but not the brakes.
then go for a drive. Haldex disengages on braking, so this should fool it into disconnecting 4x4.
on brisk acceleration, my car (remapped)will torque spin and wheel spin like an absolute pig, trying to put power down on the road through two front wheels.
so if the car is massively different in its response, its a good indicator haldex is working fine.
if its much the same as usual, you could be in 2wd.
<font color="red"> All at your own risk of course.
This is not by anyway an official test procedure, just a simple and quick way to prove either way. I do not advise you use this method for anything more than a brief test should you decide to. </font>
