smass Posted July 31, 2006 Report Share Posted July 31, 2006 I've got a MK4 GTI, tried putting new LED style rear lights on, removed the inner cover and managed to remove the bolts holding the light in place apart from the bolt holding the unit in place on the wing side of the car (this is on both side). Both of these bolts are covered by metal panels stopping me from accessing the final bolt, does anyone know of a way to get to these bolts without snapping/cracking the light cover?? Link to comment Share on other sites More sharing options...
mulkbear Posted July 31, 2006 Report Share Posted July 31, 2006 It is not a bolt, it is a push clip so in theory it should just pull off. Link to comment Share on other sites More sharing options...
Mook Posted July 31, 2006 Report Share Posted July 31, 2006 Mulky's spot on Smass - he's our resident VW tech, so he's bound to be Once you've got the nuts off the bolts, you'll need to push the light unit towards the back of the car, then ease the fixing pins that you're referring to out. Just don't rush it Link to comment Share on other sites More sharing options...
smass Posted August 1, 2006 Author Report Share Posted August 1, 2006 thanks, i'll give it a try later Link to comment Share on other sites More sharing options...
