Fergy Posted August 3, 2006 Report Share Posted August 3, 2006 Just got a Sony Ericson K750i and I cannot get it to work in the car. When the phone rings it still connects to the hanbdset rather than the car spoeakers. I have searched for the device and bluetooth is on before anyone asks. Anyone help? Link to comment Share on other sites More sharing options...
shark_90 Posted August 3, 2006 Report Share Posted August 3, 2006 Have you tried deleting the pairing and setting it back up again? And also setting the "Allow always" in the Automatically Connect option in the BT settings on the phone? I connected a K750i to mine last week, and it worked better than the K800i! Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 hi shark, just got this phone and the answering mode options are NORMAL, ANY KEY, AUTOMATIC with no option to edit them Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 my wifes Motorola L6 works superbly and autoanswers after 1 ring. PS I dont have a multifunction wheel but it works on hers Link to comment Share on other sites More sharing options...
shark_90 Posted August 3, 2006 Report Share Posted August 3, 2006 Are you able to browse the phonebook and missed/received calls etc? Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 from the steering wheel? No i dont have multifunction. Link to comment Share on other sites More sharing options...
shark_90 Posted August 3, 2006 Report Share Posted August 3, 2006 Sorry.. I was under the impression you had RNS-E The only thing I can think of is: in the phone go to Settings and COnnectivity, then Bluetooth. Go down to Handsfree, then My Handsfree in the next menu. You should be able to select the car BT as a handsfree in there. Press the "More" softkey and go to Allow connection. In that menu, select Always Allow. Those menus are from my K800i but I think they are pretty similar. Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 ok shark, thanks for the help.. the options on the audi (more ) option are SERVICES / RENAME / DELETE. On INCOMING CALL option I have Selected IN HANDSFREE. Divert Calls OFF. Accept Call ALL. Answering Mode AUTOMATIC Accessories Car HANDSFREE Link to comment Share on other sites More sharing options...
zerologic Posted August 3, 2006 Report Share Posted August 3, 2006 This maybe really stupid question but is the phone visibility turned on? it caught me out in the past. Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 visibility ON. Same thing happens in the X5 it doesnt auto answer and it goes to the handset. WTF is wrong Link to comment Share on other sites More sharing options...
PetrolDave Posted August 3, 2006 Report Share Posted August 3, 2006 Since the same thing happens in the X5, it sounds like you might have a duff handset. Link to comment Share on other sites More sharing options...
dodgy Posted August 3, 2006 Report Share Posted August 3, 2006 This behaviour happened from a certain firmware release of the K750 - it's not just you, it's everyone with the same bluetooth module that you have in your car. Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 so is this phone useless then? should I send back? Link to comment Share on other sites More sharing options...
dodgy Posted August 3, 2006 Report Share Posted August 3, 2006 It's not a great deal of use. Audi are utterly useless too, even though you'll find that your phone will work in other Audis with no problem, if your handset isn't on the 'approved' list (including firmware revision) then they won't help you. The options are to live with it, buy a different phone, get the bluetooth module changed (£). Link to comment Share on other sites More sharing options...
Big_Dan Posted August 3, 2006 Report Share Posted August 3, 2006 Is the K750i a brand spanking one? I had all sorts of minor issues as I had one of the first. I got it swapped after 11 months for a new one and all the bugs had gone. Link to comment Share on other sites More sharing options...
shark_90 Posted August 3, 2006 Report Share Posted August 3, 2006 Or of course you could use the Sony Ericsson Update Service (SEUS) to update the firmware on the phone and see if it fixes it. Also - I wasn't referring to the menu options on the car, I was referring to the menu options on the phone. It's the "Allow always" in the automatic connection bit that I'm really trying to direct you towards here. Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 Yes its brand new. how do you get the SEUS update and finally where is the Allow Always option. I dont seem to have it. Soory to be so feccking useless Just tried it in the X5 and it picks up all the names on the computer but when you dial the phone screen says 'transferred to phone' Link to comment Share on other sites More sharing options...
shipy Posted August 3, 2006 Report Share Posted August 3, 2006 Mines the same, but you do get the option when it rings to transfer the call to the car and the same on dialling out. It mutes the stereo but that’s it. The phones fine on a Motorola blue tooth headset but the calls are answered by touching the headset. I think if i had the multifunction it would work. Also updated the firmware and its made no diff. Looking at forums it seems to be a problem with the Sony handsets. I'm going to upgrade soon for a Motorola or Nokia they don't seem to have any probs. If you find the solution pls post Shipy Link to comment Share on other sites More sharing options...
shark_90 Posted August 3, 2006 Report Share Posted August 3, 2006 Not sure about the Allow Always option on a K750 but it can't be that far away from the post I made above. You can find SEUS here: http://www.sonyericsson.com/spg.jsp?cc=g...2&fid=21839 Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 Thanks Shark...Resigned to the fact that Ill send it back and stick with my cradle and Nokia 6100. Sod the Bluetooth. BMW salesman said can have upto 8 phones on at once on bluetooth in the X5. Just tried connecting both and only allows 1. Hence waste of time having 2 bluetooths in car at once. Thanks for the advice guys Link to comment Share on other sites More sharing options...
shark_90 Posted August 3, 2006 Report Share Posted August 3, 2006 I think he would have meant 8 phones paired at once - most Bluetooth devices can only have one active connection at a time. Sorry you couldn't sort it mate! Link to comment Share on other sites More sharing options...
Fergy Posted August 3, 2006 Author Report Share Posted August 3, 2006 no worries, decided to get this as my latest gadget http://shop.instant-shop.com/Snooperdirect/product540186.html Link to comment Share on other sites More sharing options...
