kite Posted August 17, 2006 Report Share Posted August 17, 2006 Had MOT yesterday and got an advisary, N/S headlamp aim slightly out. Question is, how do I adjust, is it through VAG COM or a manual adjustment on the unit somewhere ! Link to comment Share on other sites More sharing options...
Tobes49 Posted August 17, 2006 Report Share Posted August 17, 2006 Slightly out to what? High,Low,left or right? Wouldn't worry about it. Link to comment Share on other sites More sharing options...
kite Posted August 17, 2006 Author Report Share Posted August 17, 2006 OK I'll stop worrying, but I'd like it fixed ! Link to comment Share on other sites More sharing options...
Tobes49 Posted August 17, 2006 Report Share Posted August 17, 2006 [ QUOTE ] OK I'll stop worrying, but I'd like it fixed ! [/ QUOTE ] Untill you find out what way the headlamp is out you cant adjust it. You will have to pop it back to the garage and get them to tell you which way to adjust it. Link to comment Share on other sites More sharing options...
ashleyadam Posted August 17, 2006 Report Share Posted August 17, 2006 I thought xenon's where self adjusting Link to comment Share on other sites More sharing options...
PetrolDave Posted August 17, 2006 Report Share Posted August 17, 2006 [ QUOTE ] I thought xenon's where self adjusting [/ QUOTE ] They're self-levelling, not self adjusting. So left/right aim is manual, and up/down aim they just attempt to always keep it pointing the same whether the car is empty or fully laden - which means if their starting point is wrong then they'll always be wrong! Link to comment Share on other sites More sharing options...
kite Posted August 17, 2006 Author Report Share Posted August 17, 2006 Advice slip says " offside aim slightly high". Dealer told me 1hr labour and has to be done with VAGCOM. Are they fibbing ! Link to comment Share on other sites More sharing options...
Paul Posted August 17, 2006 Report Share Posted August 17, 2006 No they are not. You have to set the lights to a neutral home positon first with their diagnostics/vag-com and then make adjustments, and reset with vag-com. It could be argued they they could do it in 1/2 hr, but it might be their standard chearge etc. Link to comment Share on other sites More sharing options...
kite Posted August 17, 2006 Author Report Share Posted August 17, 2006 Thanks Paul, peterb is going to have a look at Windsor next week. Do you know where we can find the settings in VAG COM. Link to comment Share on other sites More sharing options...
Paul Posted August 17, 2006 Report Share Posted August 17, 2006 Ross-Tech Vag-com procedure HERE Link to comment Share on other sites More sharing options...
kite Posted August 20, 2006 Author Report Share Posted August 20, 2006 Cheers PaulS3. Any idea where the adjusters are on the headlamp ? Link to comment Share on other sites More sharing options...
Paul Posted August 22, 2006 Report Share Posted August 22, 2006 could be anywhere dependant on headlight. some accessable from the top, or from behind, and some are set up internally as well as the exterior adjusters, though you really should not be touching these. Link to comment Share on other sites More sharing options...
