313lb/ft?
Riz
[/ QUOTE ]Really! jump.gif
I can get the diesel tuning module for £240.00 iirc.... 200bhp / 313lb/ft!
I looked into a 'module' that made claims of high HP / LBs figures, but I can only see those figures coming froma RR session and custom map. Can't see how someone can dial in a preset map and make the car response properly all in advance of know the actual car that its going into.
I've heard good things about the 150hp 1.9 TDi VX tuning, but the remap figures are simlar to the VAG, ie 180-185hp and 300lbs ish.
Plus, with that sort of pwoer you'd need to improve the inatke cooling or you'll be losing up to 15% thru heat soak on a hot day.
I've just put a www.MrHoot.com in my recently acquired 3.0v6CDTi Signum..and to be honest it IS much better, less lag, less soot and awesone in the midrange (no slouch before)..but it didn't blow me away in the way I expected "25% more" would... high expectations, lower reality, maybe more my fault than theirs. I got it off ebay for £167 and the support before, during and after was top notch..they'reand they say they make it in UK, not ship it in. They're only an hours drive from me too which is reassuring. Put in a K&N panel too... alledgedly it will give 215hp and 322lb/ft. New to diesel and LOVING IT! the v6 sounds gorgeous too! better than the 944 turbo I sold to get it (couldn't commute in that).
Average mpg has increased by 2 aswell from 41 to 43 and I've only had it in 2 days!
Remaps/tuning boxes are a cheap way of getting a lot more power for a reason - The car will smoke twice as much, the turbo may blow up, it will kill the warranty and probably over stress the chassis and brakes.
I'd just save for a quicker car.
Probably erring on the side of negative wee bit aren't we?
I agree with what you're saying, but modern cars can take a bit of beating before going pop. I tend to agree that brakes and suspension should go hand in hand with remaps.
Also, don't forget that most cars ECUs are tunbed for a happy medium between power and economy, so reammping a wee bit to get some more HP while losing a couple of MPGs is sill within the boundairies of the cars capabilities and tolerances, so they're quite safe and good value for money.
I'm afraid you know absolutely nothing about engines if that is your opinion! 169144-ok.gif
Take a little time to research the subject and talk to a few experts and you will know more about the subject to make a better informed opinion in future. znaika.gif
For your information, I know of plenty of remapped cars that have covered well in excess of 100k since remap with no issues whatsoever. A well tuned remap of a diesel will produce no more smoke than a standard car, will be well within the engine paramaters and provided correct maintenance and servicing is carried out (on top of the reccomended servicing) the engine won't die, and neither will the turbo.
Your comments are laughable.
I would seriously advise a remap rather than a tuning box. You'll get more power for a start, and a tuning box in itself is no bad thing - but they do have a greater tendancy to create a bit of smoke than a remap due to the upping of the fuel delivery without increased boost.
Either way, unless you redline it everywhere you're not going to blow up your engine or turbo as the poster above suggests wink.gif
  • 3 weeks later...
wink.gif I must agree, I have re-mapped all my diesels and they never missed a beet for 1000's of miles. 169144-ok.gif
Sounds like a recipe for a lot of wheelspin and torque steer to me! I hope you can turn it off in the wet…..!!
That is what your right foot is for!
[/ QUOTE ]Well as you said, its all about how you use your right foot..... cant wait... should be with me tomorrow...
Fair point, but if you can't use full throttle then doesn't that sort of defeat the point confused.gif
[/ QUOTE ]Well im going to treat the car just like them big monster AMG`s with 700nm`s of torque..... just dont put your foot down going around a corner yelrotflmao.gif
It will be fun when on straight roads.... and when you see the passengers head bobbing backwards and forwards violently.... and then they develop a headache.... then they jump out and puke! shocked.giflaugh.gif
Woooohooooo
