Microsoft cause Xbox 360 problems
Sparky
Just so you know, Microsoft have put out a dodgy Autumn update, that has been affecting some 360 users, causing their machines to freeze up.
We’re aware that a very small number of Xbox 360 customers have been experiencing some issues with their console after the Autumn Update has been applied. We’re working with each customer individually to resolve any problems. Any Xbox 360 customers who have any issues with their console should contact the customer service team on 0870 60 10 100.
More here: http://www.reghardware.co.uk/2006/11/09/xbox_update_blunder/
To ‘chip’ an Xbox 360 all that is required is modified firmware to be loaded on the DVD drive. Very easy to do sekret.gif
This allows you to make backups from your Xbox 360 and play your backups on it so your originals don’t get damaged. znaika.giftongue.gif
The fall update does not disable these modified drives so the consensuses of opinion is there must be another reason for the problems.
Microsoft is getting over the problem of hacked drives by now supplying Xbox 360 DVD drives that can not be modified without the removal of the chip.
They lock the chip in place with black resin to prevent removal although this bit has now been cracked.
However new firmware for this new drive has not be cracked as of yet leading to speculation Microsoft will used hardware updates to prevent the problem rather than software.
so basically unplug your hard-drive.. see which type it is and then remove and update via your pc and then re-insert!!
Doesn't seem to difficult.. but not something i'd want to do. I know you can pick up games for a fiver, but i honestly like to think that my money goes to the software house so they can develop new games, than go to organised crime.
