Cisco 837
Dave
So if i replace my current hub (with the 4 pc's connected) with this cisco switch, will i have much set up to do?
I have fixed ip addresses on all the computers.. along the lines of 192.168.1.1 and the 192.168.1.2 for another etc.
Would it be a case of attach it to one computer, complete the set up and then connect the other 3?
Building configuration...
Current configuration : 8338 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec
service timestamps log datetime localtime
service password-encryption
no service dhcp
hostname ABCDEF
boot-start-marker
boot-end-marker
memory-size iomem 5
no logging buffered
no logging console
enable secret 5 "It's a secret"
aaa new-model
aaa authentication login default local
aaa authorization auth-proxy default local
aaa session-id common
resource policy
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
ip subnet-zero
no ip source-route
ip cef
no ip domain lookup
ip domain name "It's a secret"
no ip bootp server
ip inspect udp idle-time 10
ip inspect tcp idle-time 300
ip inspect tcp synwait-time 10
ip inspect name FW-OUTSIDE tcp
ip inspect name FW-OUTSIDE udp
ip inspect name FW-OUTSIDE icmp
ip inspect name FW-OUTSIDE smtp
ip ips sdf location <a href="flash://attack-drop.sdf" target="_blank">flash://attack-drop.sdf</a>
ip ips name IDS
ip ssh authentication-retries 1
ip ssh version 2
login block-for 300 attempts 2 within 60
login quiet-mode access-class TELNET
login on-failure log
login on-success log
interface Null0
no ip unreachables
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Ethernet0
description INSIDE
bandwidth 100000
ip address 192.168.16.30 255.255.255.248
no ip redirects
ip nat inside
ip virtual-reassembly
ip route-cache flow
hold-queue 100 out
interface Ethernet2
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
hold-queue 100 out
interface ATM0
description Physical for Dialer0
bandwidth 8192
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
shutdown
duplex auto
speed auto
interface FastEthernet3
shutdown
duplex auto
speed auto
interface FastEthernet4
shutdown
duplex auto
speed auto
interface Dialer0
description OUTSIDE
bandwidth 8192
ip address "It's a secret" 255.255.255.0
ip access-group OUTSIDE in
ip verify unicast source reachable-via rx
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip nat outside
ip inspect FW-OUTSIDE out
ip ips IDS in
rate-limit input access-group 190 512000 1500 2000 conform-action transmit exceed-action drop
rate-limit input access-group 191 128000 1500 2000 conform-action transmit exceed-action drop
rate-limit input access-group 192 128000 1500 2000 conform-action transmit exceed-action drop
encapsulation ppp
ip route-cache flow
ip policy route-map black-hole
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname "It's a secret"
ppp chap password 7 "It's a secret"
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip flow-export source Ethernet0
ip flow-export version 5 peer-as
ip nat inside source list 10 interface Dialer0 overload
ip nat inside source static tcp 192.168.16.29 25 interface Dialer0 25
ip nat inside source static tcp 192.168.16.29 3389 interface Dialer0 3389
ip nat inside source static tcp 192.168.16.29 80 interface Dialer0 80
ip access-list extended BLACK-HOLE
permit ip 0.0.0.0 1.255.255.255 any
permit ip 2.0.0.0 0.255.255.255 any
permit ip 5.0.0.0 0.255.255.255 any
permit ip 7.0.0.0 0.255.255.255 any
permit ip 10.0.0.0 0.255.255.255 any
permit ip 23.0.0.0 0.255.255.255 any
permit ip 27.0.0.0 0.255.255.255 any
permit ip 31.0.0.0 0.255.255.255 any
permit ip 36.0.0.0 1.255.255.255 any
permit ip 39.0.0.0 0.255.255.255 any
permit ip 42.0.0.0 0.255.255.255 any
permit ip 49.0.0.0 0.255.255.255 any
permit ip 50.0.0.0 0.255.255.255 any
permit ip 77.0.0.0 0.255.255.255 any
permit ip 78.0.0.0 1.255.255.255 any
permit ip 92.0.0.0 3.255.255.255 any
permit ip 96.0.0.0 15.255.255.255 any
permit ip 112.0.0.0 7.255.255.255 any
permit ip 120.0.0.0 0.255.255.255 any
permit ip 127.0.0.0 0.255.255.255 any
permit ip 169.254.0.0 0.0.255.255 any
permit ip 172.16.0.0 0.15.255.255 any
permit ip 173.0.0.0 0.255.255.255 any
permit ip 174.0.0.0 1.255.255.255 any
permit ip 176.0.0.0 7.255.255.255 any
permit ip 184.0.0.0 3.255.255.255 any
permit ip 192.0.2.0 0.0.0.255 any
permit ip 192.168.0.0 0.0.255.255 any
permit ip 197.0.0.0 0.255.255.255 any
permit ip 198.18.0.0 0.1.255.255 any
permit ip 223.0.0.0 0.255.255.255 any
permit ip 224.0.0.0 31.255.255.255 any
deny ip any any
ip access-list extended OUTSIDE
deny ip 0.0.0.0 1.255.255.255 any log-input
deny ip 2.0.0.0 0.255.255.255 any log-input
deny ip 5.0.0.0 0.255.255.255 any log-input
deny ip 7.0.0.0 0.255.255.255 any log-input
deny ip 10.0.0.0 0.255.255.255 any log-input
deny ip 23.0.0.0 0.255.255.255 any log-input
deny ip 27.0.0.0 0.255.255.255 any log-input
deny ip 31.0.0.0 0.255.255.255 any log-input
deny ip 36.0.0.0 1.255.255.255 any log-input
deny ip 39.0.0.0 0.255.255.255 any log-input
deny ip 42.0.0.0 0.255.255.255 any log-input
deny ip 49.0.0.0 0.255.255.255 any log-input
deny ip 50.0.0.0 0.255.255.255 any log-input
deny ip 77.0.0.0 0.255.255.255 any log-input
deny ip 78.0.0.0 1.255.255.255 any log-input
deny ip 92.0.0.0 3.255.255.255 any log-input
deny ip 96.0.0.0 15.255.255.255 any log-input
deny ip 112.0.0.0 7.255.255.255 any log-input
deny ip 120.0.0.0 0.255.255.255 any log-input
deny ip 127.0.0.0 0.255.255.255 any log-input
deny ip 169.254.0.0 0.0.255.255 any log-input
deny ip 172.16.0.0 0.15.255.255 any log-input
deny ip 173.0.0.0 0.255.255.255 any log-input
deny ip 174.0.0.0 1.255.255.255 any log-input
deny ip 176.0.0.0 7.255.255.255 any log-input
deny ip 184.0.0.0 3.255.255.255 any log-input
deny ip 192.0.2.0 0.0.0.255 any log-input
deny ip 192.168.0.0 0.0.255.255 any log-input
deny ip 197.0.0.0 0.255.255.255 any log-input
deny ip 198.18.0.0 0.1.255.255 any log-input
deny ip 223.0.0.0 0.255.255.255 any log-input
deny ip 224.0.0.0 31.255.255.255 any log-input
deny icmp any any log-input fragments
permit tcp any host "It's a secret" eq 22 log-input
permit tcp any host "It's a secret" eq smtp
permit tcp 16.8.0.0 0.0.255.255 host "It's a secret" eq 3389
deny ip any any log-input
ip access-list extended TELNET
permit ip host 192.168.16.29 any
logging trap notifications
logging source-interface Ethernet0
logging 192.168.16.29
access-list 10 permit 192.168.16.24 0.0.0.7
access-list 190 remark CAR-UDP
access-list 190 permit udp any any
access-list 191 remark CAR-ICMP
access-list 191 permit icmp any any
access-list 192 remark CAR-Multicast
access-list 192 permit ip any 224.0.0.0 15.255.255.255
dialer-list 1 protocol ip permit
no cdp run
route-map black-hole permit 1
match ip address BLACK-HOLE
set interface Null0
control-plane
banner motd ^CC
* THIS COMPUTER SYSTEM IS FOR AUTHORISED OFFICIAL USE ONLY. *
* The use of this computer system will be subject to monitoring *
* and recording without further notice. Auditing may include the *
* use of keystroke monitoring. *
* Any individual who uses this system expressly consents to such *
* monitoring and is advised that information about their use of *
* this system may be provided to the relevant authorities if *
* evidence of criminal or other unauthorised activity is found. *
^C
line con 0
exec-timeout 0 0
no modem enable
line aux 0
transport output none
line vty 0
exec-timeout 2 0
logging synchronous
transport input ssh
transport output ssh
line vty 1
access-class TELNET in
exec-timeout 3 0
logging synchronous
transport input ssh
line vty 2 4
transport input none
scheduler max-task-time 5000
scheduler interval 500
sntp server 129.132.2.21
sntp server 130.149.17.8
end
complete the set up
Have a go, when you have had enough of International phone calls & found you don't have a support contract, do as Mac says & buy a Linksys.
Seriously a Linksys/ASDL modem/router will do all you want to do, take about 10 minutes to set up & give you a wireless option too - its just not worth the pain !
