andyf Posted November 24, 2006 Report Share Posted November 24, 2006 Does this seem like a good price, front discs OEM, front pads replacement, rear discs replacement, rear pads OEM. I know its a bit of a mix of OEM and replacement but the replacement parts are a supplier to VW. Link to comment Share on other sites More sharing options...
Mook Posted November 24, 2006 Report Share Posted November 24, 2006 £419 is a good price, esp. given that a set of front disks and pads from VW is about £500 IIRC. Don't forget that if the "replacement parts" are from a supplier to VW, these are technically OEM, so you should be fine. Link to comment Share on other sites More sharing options...
alexc Posted November 24, 2006 Report Share Posted November 24, 2006 checkout www.gsfcarparts.com they sell Brembo discs and Pagid pads, more than upto thje job and probably much cheaper. Link to comment Share on other sites More sharing options...
Mook Posted November 24, 2006 Report Share Posted November 24, 2006 Err big time on the side of caution with Pagid pads. They are fine on non-performance cars (run them on Mrs Mook's Passat) but they fade like buggery on a stock R32. Link to comment Share on other sites More sharing options...
khutula Posted November 24, 2006 Report Share Posted November 24, 2006 I have just taken order of these. I only ordered them on Wednesday afternoon. Good service and genuine parts Link to comment Share on other sites More sharing options...
alexc Posted November 24, 2006 Report Share Posted November 24, 2006 [ QUOTE ] Err big time on the side of caution with Pagid pads. They are fine on non-performance cars (run them on Mrs Mook's Passat) but they fade like buggery on a stock R32. [/ QUOTE ] It depends on what ones you go for, the standard Pagid pads are fine for non performance cars but they also make a Performance range to suit. I run them on a car with 300+ bhp and they're fine! Link to comment Share on other sites More sharing options...
Mook Posted November 24, 2006 Report Share Posted November 24, 2006 Valid point Alex - what performance car do you run them on. From experience, a lot comes down to the weight of the car. I tried two flavours of Pagid pads when I had standard brakes and they both faded. Badly... Link to comment Share on other sites More sharing options...
alexc Posted November 24, 2006 Report Share Posted November 24, 2006 [ QUOTE ] Valid point Alex - what performance car do you run them on. From experience, a lot comes down to the weight of the car. I tried two flavours of Pagid pads when I had standard brakes and they both faded. Badly... [/ QUOTE ] That could be the case, I run mine in a Mk2 Golf with a TT engine transplanted (with modifications)! Link to comment Share on other sites More sharing options...
Mook Posted November 24, 2006 Report Share Posted November 24, 2006 Reckon that's why - about 1100KG IIRC. The R32 is a heavy lump at over 1500KG. Neat conversion though Link to comment Share on other sites More sharing options...
RedRobin Posted November 24, 2006 Report Share Posted November 24, 2006 [ QUOTE ] Don't forget that if the "replacement parts" are from a supplier to VW, these are technically OEM, so you should be fine. [/ QUOTE ] ....You should be fine with your VW dealer anyway. European law passed in around 2003 called 'Block Exemption Ruling' doesn't allow a dealer to dictate what you can and can't do. They and not you, have to prove in a court of law that the non-OEM product was the direct cause of a warranty issue. My VW dealer is totally happy about all my mods and has even installed some of them. They are also happy if I remap and when I discussed my intention to upgrade my OEM front brakes to AP Racing BB kit with DS2500 pads and all the rest of the biz, they said they had no problem servicing but I would have to supply the new pads for them to fit as they weren't a stock item. AP Racing (owned by Brembo) fitted my brakes and supplied me with an Owner's Handbook and fully exploded working drawing and parts list of the kit. AP Racing BB thread Link to comment Share on other sites More sharing options...
Brisel Posted November 24, 2006 Report Share Posted November 24, 2006 [ QUOTE ] Valid point Alex - what performance car do you run them on. From experience, a lot comes down to the weight of the car. I tried two flavours of Pagid pads when I had standard brakes and they both faded. Badly... [/ QUOTE ] Bugg€r. Did you try the Pagid Orange RS44 pads, Mook? The Pagids were heavily recommended by my local VAG tuner, Jabbasport. Hope they will be ok for the occasional track day Link to comment Share on other sites More sharing options...
robin09 Posted November 24, 2006 Report Share Posted November 24, 2006 [ QUOTE ] I have just taken order of these. I only ordered them on Wednesday afternoon. Good service and genuine parts [/ QUOTE ] They're pretty cheap! Are they definitely genuine? Seeing as how I'm still on the original discs after 43k miles and 3 trips to the Ring, I may have to buy a set soon. Link to comment Share on other sites More sharing options...
RossG Posted November 24, 2006 Report Share Posted November 24, 2006 Yes they are genuine, I got a set from there a couple of weeks ago. Fitted the other day - muchos improvement Link to comment Share on other sites More sharing options...
deathchurch Posted November 27, 2006 Report Share Posted November 27, 2006 He quoted me £500 just the other week, how come you got £419, good job I didn't order them. Link to comment Share on other sites More sharing options...
Mook Posted November 27, 2006 Report Share Posted November 27, 2006 [ QUOTE ] Did you try the Pagid Orange RS44 pads, Mook? The Pagids were heavily recommended by my local VAG tuner, Jabbasport. Hope they will be ok for the occasional track day [/ QUOTE ] No, I didn't. And AFAIK, Jabba don't do much (if any) work on R32's, so I don't know how well qualified that recommendation may have been. You're just going to have to try them and see. Link to comment Share on other sites More sharing options...
Brisel Posted November 27, 2006 Report Share Posted November 27, 2006 [ QUOTE ] [ QUOTE ] Did you try the Pagid Orange RS44 pads, Mook? The Pagids were heavily recommended by my local VAG tuner, Jabbasport. Hope they will be ok for the occasional track day [/ QUOTE ] No, I didn't. And AFAIK, Jabba don't do much (if any) work on R32's, so I don't know how well qualified that recommendation may have been. You're just going to have to try them and see. [/ QUOTE ] Cheers Mook Jabbasport are mainly "forced induction" specialists & have only recently started doing work on R32s in response to customer demand. So far, so good with the Orange Pagid pads (already fitted) but I haven't really given them a thorough testing yet. Link to comment Share on other sites More sharing options...
robs1977 Posted November 28, 2006 Report Share Posted November 28, 2006 [ QUOTE ] He quoted me £500 just the other week, how come you got £419, good job I didn't order them. [/ QUOTE ] Becauase his quote of £419 was from somone else with non gen pads and rear discs. Link to comment Share on other sites More sharing options...
deathchurch Posted November 30, 2006 Report Share Posted November 30, 2006 Ah, that makes sense then. I take it your Dsgwagen from ebay, I haven't forgotten about your deal, I just need to find somewhere I trust to fit them, or else its me paying through the nose at the dealers. Link to comment Share on other sites More sharing options...
robs1977 Posted December 2, 2006 Report Share Posted December 2, 2006 No worries,just give us a shout if you want them. Link to comment Share on other sites More sharing options...
