TDiAvant Posted January 25, 2007 Report Share Posted January 25, 2007 I’ve just finished installing the MFSW on my B7 S4 . Here is a quick write-up on the installation. First Disconnect the Negative lead going to the battery. Remove the two clips either side of the steering wheel, and remove the torx’s screws which hold the air bag module in place. Unclip the airbag wiring harness connector and remove the airbag. Remove the spilled blot holding the wheel in place. You should put this bolt in the bin and buy a new bolt, as it’s a thread lock type bolt. Remove the steering wheel cowling and Slip Ring module module as described in the Cruise Control Retrofit post. Fit the new Slip ring and refit the cowling. See in the picture bellow the different between the two slip rings the correct slip ring has 12 pin’s the top six are for the airbag and the bottom six are for the Multifunction controls on the wheel. Remove the old wiring harness from the airbag module, to do this prise the yellow plastic up on each of the connectors, and remove both spade connectors you will then be able to remove the green and orange connector from the airbag. Install the new wiring harness and double/triple check the connectors are secure. Fit the new multifunction wheel to the car and connect use the new thread lock bolt. Connect the airbag wiring harness connector to the multifunction wheel connector, and push it into it’s fitting location. Connect the airbag wiring harness to the slip ring, when it’s pushed all the way down you will hear a click. tighten down the two torx head screws which hold the airbag in place and put the clips back to cover the holes Reconnect the battery. You will then need a VAG com to recode the SCSM for MFSW, and depending on what options you have like RNS-E and Bluetooth you will need to recode them for MFSW. There will also be a fault code on the Engine due to you disconnecting the battery, just clear this fault. Link to comment Share on other sites More sharing options...
Sponge Posted January 25, 2007 Report Share Posted January 25, 2007 You've been busy little bee. Link to comment Share on other sites More sharing options...
MarkB Posted January 25, 2007 Report Share Posted January 25, 2007 So all the wiring is in place for the swap? How much did the wheel cost? Thanks Link to comment Share on other sites More sharing options...
TDiAvant Posted January 25, 2007 Author Report Share Posted January 25, 2007 For the B7 all the wiring is in place, but I'm not sure about B6, B5 models. I think I paid about £230 for the wheel. Link to comment Share on other sites More sharing options...
PetrolDave Posted January 25, 2007 Report Share Posted January 25, 2007 [ QUOTE ] For the B7 all the wiring is in place, but I'm not sure about B6, B5 models. I think I paid about £230 for the wheel. [/ QUOTE ] The B7 has a dual stage airbag, but the B6 only has a single stage airbag - don't know about the B5. Link to comment Share on other sites More sharing options...
TDiAvant Posted January 25, 2007 Author Report Share Posted January 25, 2007 Good point Dave, I was just talking about the Multifunction side of this install and not the aribag. Question. Was there ever an option for multifunction on the B5 range? Link to comment Share on other sites More sharing options...
PetrolDave Posted January 25, 2007 Report Share Posted January 25, 2007 [ QUOTE ] Good point Dave, I was just talking about the Multifunction side of this install and not the airbag. [/ QUOTE ] It means you can't fit a B7 MFSW to a B6 or B5, but a B6 MFSW "might" fit a B5 if there wasn't an MFSW option on the B5? Link to comment Share on other sites More sharing options...
Davef Posted January 25, 2007 Report Share Posted January 25, 2007 Excellent posts. As you know I am planning the exact same mods so you have certainly made my job easier. Shame (forme!) that you've already got xenons!! Dave Link to comment Share on other sites More sharing options...
TDiAvant Posted January 25, 2007 Author Report Share Posted January 25, 2007 I must admit I would have done the full retrofit for the Xenons. (Thank feck the car had them on as standard)Even down to replacing the bumper to fit the washers Good luck on your retrofits if you need any more info just PM me. Link to comment Share on other sites More sharing options...
moose73 Posted January 28, 2008 Report Share Posted January 28, 2008 is the steering wheel bolt, torx? if so what size? Link to comment Share on other sites More sharing options...
moose73 Posted January 28, 2008 Report Share Posted January 28, 2008 read elsewhere it maybe M12 12 toothed spline, is this correct? Link to comment Share on other sites More sharing options...
shark_90 Posted January 28, 2008 Report Share Posted January 28, 2008 T55 fits, also a spline drive fits but I can't remember what size. Link to comment Share on other sites More sharing options...
jwhat Posted February 19, 2009 Report Share Posted February 19, 2009 Would you have the part number for the new wiring harness by any chance? Link to comment Share on other sites More sharing options...
nerokid Posted May 27, 2009 Report Share Posted May 27, 2009 Will this work on all A4 B7?? Link to comment Share on other sites More sharing options...
shark_90 Posted May 28, 2009 Report Share Posted May 28, 2009 If you change the Steering Wheel control module then yes. I've done a few. Link to comment Share on other sites More sharing options...
nerokid Posted May 28, 2009 Report Share Posted May 28, 2009 If you change the Steering Wheel control module then yes. I've done a few. What is the Steering Wheel control module and do you know what it cost? Picture off the sterng wheel i gott:o Link to comment Share on other sites More sharing options...
shark_90 Posted May 28, 2009 Report Share Posted May 28, 2009 Steering wheel control module is around £125 and will need coding with VCDS. Link to comment Share on other sites More sharing options...
nerokid Posted July 15, 2009 Report Share Posted July 15, 2009 For the B7 all the wiring is in place, but I'm not sure about B6, B5 models. I think I paid about £230 for the wheel. No wiring was inn place for mine B7:( Link to comment Share on other sites More sharing options...
nerokid Posted July 15, 2009 Report Share Posted July 15, 2009 Steering wheel control module is around £125 and will need coding with VCDS. where can i order a Steering Wheel control module?? Link to comment Share on other sites More sharing options...
Cupramax Posted July 15, 2009 Report Share Posted July 15, 2009 How about Tesco's...or Asda... no seriously, how about your dealer? Link to comment Share on other sites More sharing options...
shark_90 Posted July 15, 2009 Report Share Posted July 15, 2009 Yep dealer. You may also need to change the slip ring for a 12 pin one. Link to comment Share on other sites More sharing options...
micalee Posted July 16, 2009 Report Share Posted July 16, 2009 The original pictures are not showing - can anyone else confirm this? Would like to see them Link to comment Share on other sites More sharing options...
Yemiboy Posted August 24, 2011 Report Share Posted August 24, 2011 For the B7 all the wiring is in place, but I'm not sure about B6, B5 models. I think I paid about £230 for the wheel. TDiAvant, How would I know if my wiring are in place for the MFSW? I have just bought a MFSW from an Audi A8 to be fitted in my Audi A4 Convertible Registered March 2005, I called Audi to find out if my Car was B6 or B7 and I was told it is B7 but I am not sure if the wiring are in place for me to Retrofit this, can you send me some pix of yours as the pictures you posted are no longet available. Link to comment Share on other sites More sharing options...
garcon magnifique Posted August 25, 2011 Report Share Posted August 25, 2011 Not seen TDiAvant in these parts for a loooong time and he's had about four cars since that S4. A couple of others may be able to help. I suspect the internals of a 2005 cab will be closer to B6 than B7? Link to comment Share on other sites More sharing options...
Yemiboy Posted August 25, 2011 Report Share Posted August 25, 2011 Thanks for the update garcon, I spoke to Audi and the confirm my car is B7. I spoke to the person I bought the MFSW from and he said it is a staight swap, as the steering comes with the airbag and all needed, I will post some pictures ans I will make a video of the swap to help others willing to do the same. I did a dry run of removng my current one yesterday and I was successful. Link to comment Share on other sites More sharing options...
