[Audi A3/S3] Random Idle on 2.0TDi 170 A3
philpatton
Every once in a while my A3 TDi 170 idles when stationary upto 1000rpm. It normally sits around 800rpm. The engine is normally at temp or thereabouts when it happens. When I set off, the diesel rumble is very noticable upto around 2ooorpm, then quietens down again as I go through the rev range. If i slow down for a corner, the rumble returns.
I had the bonnet open tonight and noticed something clicking, but it wasn't the fan. The dealers have plugged in the Ding Dang Do computer thing, but there is no fault codes. Any ideas.........anyone........please......
Not had an uneven or high idle on mine, nor clicking noises.
What I have had on a few odd occasions is where the engine suddenly sounds really rough and "agricultural", the sort of traditional noise you expect from an old diesel rather than a new one. Only happened a few times and doesn't last long, when it did happen it seemed to be on part throttle, if you gave it some beans it quietened down again. Not happened for a month or more now so maybe it's settled down.
Hmm, just been doing it again, seems totally random.
Bit more info on this:
When it happens, it's purely noise levels that increase, there is no increased vibration from the engine at all. The car also seems to hesitate a little under light acceleration, which is when the noise is most apparent. Heavy acceleration seems to be fine and the noise disappears when you stamp on it.
From reading around it appears that hesitant acceleration on part throttle is one of the symptoms of an EGR valve sticking open but everywhere I've read this also states that you'd get an uneven idle too, which I don't. Does this rule out a stuck EGR or is it possible to get this but without the uneven idle?
When it does happen it seems to be when the engine isn't fully warmed through (although not necessarily stone cold). It's possible that this behaviour is normal but I've not seen anyone else report it. Two dealers I spoke to said they'd never had this reported but then do you believe them and would most people even bother to report it if it happened that infrequently?
This could just be a vibration somewhere. Is your plastic engine cover able to move at all? My brother's Clio 172 did this until he ripped it off. Problem solved.
a3malawimatt: Actually reassuring to hear it's not just me - maybe just a facet of the engine when it's cold.
Powerphil: yeah, let us know anything you find out, as I said both dealers I spoke to just scratched their heads but then it's never happened whilst the car has been at the dealer.
Just had it again. Very interesting comment about the restart as both today and yesterday it happened after a short drive. Popped out to lunch so short trip, then when I came back it happened.
It's definitely more than a noise - acceleration is very stuttery. If you sit and just rev the engine it sounds rough and there's a brief stutter as the revs rise. On the move the sound is worse and it's very stuttery when you really boot it a bit, taking a couple of seconds to knuckle down and "go".
Bet it'll be fine again come home time, as it was yesterday.
Powerphil: please post back what joy you have with the dealer as most will just check for fault codes, find none (probably) and say "nowt we can do". With the exception of the idle, which isn't lumpy or noisy, it sounds like an EGR valve problem to me, maybe suggest that to them and also mention that others are having similar issues?
I phoned the dealers today and spoke to the Workshop Manager. He isn't aware of any problems on the A3 like the one described, but he is aware of issues on the A6 EGR. What he has said is that if anyone else reports the problem, then he will send a tech report along with a diagnosis print out through to Audi and get them on it.
Keep the comments coming.
Vertigo1 - Let us know what they find out!!!
I am using Doncaster Audi. Been a customer of theirs since 2004. When I phone up, they know me by name!! If any other dealer told me what they said today I'd be " Yeah right.....can't be bothered!" So I do have faith.
What is a DPF?? It strikes me as odd that a number of people have the problem, but Audi don't know anything about it.
Happened yesterday on the way home but I noticed something very interesting. The engine had fully warmed through by the time I got home but the noise was still there. Turned ignition off, waiting a minute and then started the car again and it was gone! Completely gone!
This suggests it's electronics related rather than mechanical. Just thought I'd mention it so that, if any of you have the problem again, you can try the above and report back if this solves it for you.
  • 2 weeks later...
Hi guys. I have the exact same intermitant problem on my 170 - comes and goes at random (mostly when the engine is part warm). Went to the dealers and as others have reported 'no fault found'. Would really like to get to the bottom of it - the engine sounds and feels very rough.
  • 5 weeks later...
I've continued to have this problem on my A3 170Tdi since it was new and the car has now been back to the dealers three times - on each visit no fault was found. However I've now been told Audi issued a technical bulletin on 7th April relating to the A3 170Tdi S-tronic model which describes the symptoms reported here. It says the cause is the regeneration phase of the diesal particulate filter and describes it as a normal function of the vehicle emission systems. I don't know about you - but I don't fancy living with a car that sounds like a transit van every few days and drives badly to boot. I am extremely unhappy at the response and plan to take it up with Audi Customer Services.
