steve2 Posted July 24, 2007 Report Share Posted July 24, 2007 as per title the disc on the front has seperated from the hub? I found this out when i took the wheel off to check the suspension bushes and found the disc floating. now i know it is all held in place by the wheel bolts but i always thought they were a single item. there is a hole in the disc for a retaining screw but no hole in the hub, is this normal because i cannot remember this happening on previous discs Link to comment Share on other sites More sharing options...
Mook Posted July 24, 2007 Report Share Posted July 24, 2007 There should be a retaining screw holding the disk in place. When you take the wheel off, you should be able to rotate the disk until you see the hole it is supposed to line up with. Nothing to worry about - the wheel bolts will hold it in place Link to comment Share on other sites More sharing options...
steve2 Posted July 24, 2007 Author Report Share Posted July 24, 2007 cheers Mook, there is definatly no retaining hole though Link to comment Share on other sites More sharing options...
Mook Posted July 24, 2007 Report Share Posted July 24, 2007 Replacement disks? If so, then were they fitted by an Audi dealer? Can't remember how old your car is. Link to comment Share on other sites More sharing options...
Avus_Bub Posted July 24, 2007 Report Share Posted July 24, 2007 The front discs on my car have a screw. The rears don't have a screw. The disc is drilled/countersunk but the hub isn't........ It's not like they're going to fall off when the calipers are there! BUB Link to comment Share on other sites More sharing options...
Mook Posted July 25, 2007 Report Share Posted July 25, 2007 Or the wheel bolts holding the wheel on Link to comment Share on other sites More sharing options...
