Decked Posted July 27, 2007 Report Share Posted July 27, 2007 On a daily drive the clutch if fine but when I'm at high revs and changing gear fast the gears are grinding even though the clutch pedal is on the floor. It then takes a second for the gear to go in.... As far as I'm aware the clutch is hydraulic so it's probably got some air in the system. How do I go about bleeding it? Link to comment Share on other sites More sharing options...
Mook Posted July 27, 2007 Report Share Posted July 27, 2007 Sorry, Keith, never had to do it, so can't answer that one. I'll ask my VW tech when I see him on Monday Link to comment Share on other sites More sharing options...
Decked Posted July 28, 2007 Author Report Share Posted July 28, 2007 [ QUOTE ] Sorry, Keith, never had to do it, so can't answer that one. I'll ask my VW tech when I see him on Monday [/ QUOTE ] Thanks Link to comment Share on other sites More sharing options...
Mook Posted July 30, 2007 Report Share Posted July 30, 2007 Here you go... Pump pedal several times then hold down to floor, someone then opens clutch bleed screw to release pressure, do this several times. Should sort it. So you'll need a spare pair of hands, then. Give BIALI a call - they're bound to have some pliers... Link to comment Share on other sites More sharing options...
Decked Posted July 31, 2007 Author Report Share Posted July 31, 2007 [ QUOTE ] Here you go... Pump pedal several times then hold down to floor, someone then opens clutch bleed screw to release pressure, do this several times. Should sort it. So you'll need a spare pair of hands, then. Give BIALI a call - they're bound to have some pliers... [/ QUOTE ] Thanks for that, I think I found the bleed screw... to the left of the battery! We will see Otherwise I'll give BIALI a call Link to comment Share on other sites More sharing options...
