RobK Posted July 30, 2007 Report Share Posted July 30, 2007 Is there a quick way to turn off a radio traffic announcement on an I-drive car? While I'm at it, is there a way to have the headlights come on when you unlock the car, like my A3 used to? Link to comment Share on other sites More sharing options...
deanobeano Posted July 30, 2007 Report Share Posted July 30, 2007 if you use the steering wheel change source buttons (the up and down buttons that dont change the volume), this will change the radio station and remove the TP report - you can then press the opposite button to take you back to what you were listing to before. Link to comment Share on other sites More sharing options...
gizze Posted August 1, 2007 Report Share Posted August 1, 2007 Press the i-drive controller down with the radio playing and you get a set of options, one of them is TP and you can un-check it. Link to comment Share on other sites More sharing options...
RobK Posted August 1, 2007 Author Report Share Posted August 1, 2007 [ QUOTE ] if you use the steering wheel change source buttons (the up and down buttons that dont change the volume), this will change the radio station and remove the TP report - you can then press the opposite button to take you back to what you were listing to before. [/ QUOTE ] Tried it this morning and found you actually only have to press the button once to cancel the traffic report. Thanks! Link to comment Share on other sites More sharing options...
RobK Posted August 1, 2007 Author Report Share Posted August 1, 2007 [ QUOTE ] Press the i-drive controller down with the radio playing and you get a set of options, one of them is TP and you can un-check it. [/ QUOTE ] True, but I wanted to leave TP on and just cancel the current announcement. Anyway I use the voice control for "TP on" and "TP off", works a treat Link to comment Share on other sites More sharing options...
Tizzy Posted August 1, 2007 Report Share Posted August 1, 2007 The headlights can be set on the I-Drive menu under lights - allows you to set the time for what it calls "Welcome Lights" which turn on when you unlock the car. Link to comment Share on other sites More sharing options...
