jon1 Posted August 5, 2007 Report Share Posted August 5, 2007 I HAVE A PROBLEM WITH MY SATNAV DVD THAT IT WONT READ AND AUDI WANT £250+VAT FOR A REPLACMENT JUST WONDERING IF ANYONE HAS A CHEAPER SOLUTION THE SAT NAV UNIT IS THE CURRENT MODEL. Link to comment Share on other sites More sharing options...
TDiAvant Posted August 5, 2007 Report Share Posted August 5, 2007 Seeing as you already have a licensed DVD, PM me and I can send you a backup copy One thing, CAPS = SHOUTING Link to comment Share on other sites More sharing options...
craigyb Posted August 5, 2007 Report Share Posted August 5, 2007 If your sat nav won't read an original, I very much doubt that a copy will work unless the original is damaged beyond readability. Link to comment Share on other sites More sharing options...
PetrolDave Posted August 5, 2007 Report Share Posted August 5, 2007 If your sat nav won't read an original DVD then you should try a DVD lens cleaner disc. Link to comment Share on other sites More sharing options...
TDiAvant Posted August 5, 2007 Report Share Posted August 5, 2007 It could be that the disk is damaged, and needs replacing. it's worth a try. I know I would try another disk before replacing the nav unit. Link to comment Share on other sites More sharing options...
PetrolDave Posted August 5, 2007 Report Share Posted August 5, 2007 Try putting the DVD you have in your PC and copying the files into a temporary directory. That will force your PC to read all the files on the disk - if the copy is successful then there is nothing wrong with your DVD. Link to comment Share on other sites More sharing options...
