A4 Tyre Pressures (19 inch wheels)
gtiller
I know this has been debated numerous times ZZZ.gif but I wanted a few fresh opinions please...
I have a B7 A4 3.0 TDi Quattro with the tiptronic box.
In SE spec it had 16 inch wheels, which have now been swapped out for 19 inch RS6 replicas.
I am running Michelin Pilot Sport 2 tyres (hopefully the right choice, for someone that does a lot of motorway miles, and likes a quiet life)
The wheel style and tyre make are the right size (for driveabilty/speedo calibration etc...) at 235/35 19, and were chosen with your recommendations - THANKS GUYS!
However, the car fecking heavy at 1705Kg
I think this is pretty similar to S4 Avant with Tiptronic
Most people are putting these wheels on smaller displacement petrol engined/manual transmission cars which means 200 - 400 Kilos lighter in weight
So what tyre pressures do you think I should be running at?
Also, with such a big lump at front, what is the weight distribution like, and should the pressures be different from fron to rear (9 times out of ten, there are only ever two people in the car, with no load in the back)
I am currently at 36 all round which seems OK, but I want to make sure I get the longest life/best experience out of them, and not over or under inflate!
Hi mate, I have an A4 3.0TDI q cab - 200kilos heavier than yours!
I run 38 all round. depends on the tyre though.
The A4 3.0TDI q is lighter than the S4 so its not that big a lump up front!
Weight distribution is pretty good in the cab! - but it has extra rigidity on rear panels and roof mechanicsm and anti roll supports which are all heavy so that will help.
Also keep petrol tank full and keep seats back - makes a difference!
