TrundleFly Posted April 17, 2016 Report Share Posted April 17, 2016 Hello all I have a 2012 A7 with SIM slot and Google maps etc. I gather it is not possible to use a SIM in the car AND use Bluetooth to my mobile phone for calls at the same time. However it seems this is possible with newer cars. Does anyone know if this can be enabled in older cars like mine through an MMI software update? Thanks for any answers. Link to comment Share on other sites More sharing options...
chasdrury Posted April 17, 2016 Report Share Posted April 17, 2016 Yes, you need a firmware update and to enable it by the engineering screen which needs to be activated with VCDS Link to comment Share on other sites More sharing options...
TrundleFly Posted April 18, 2016 Author Report Share Posted April 18, 2016 Thanks. Is that something Audi need to do or can a good independent with the right kit also do it? Link to comment Share on other sites More sharing options...
chasdrury Posted April 18, 2016 Report Share Posted April 18, 2016 Thanks. Is that something Audi need to do or can a good independent with the right kit also do it? Audi won't do it! unless the firmware fixes an issue. I have tried and tried to do it with them but it's a no! Link to comment Share on other sites More sharing options...
PeterS Posted April 18, 2016 Report Share Posted April 18, 2016 My A3 does let the MMI use the cars data connection for Google maps and creating a wifi hotspot in the car while using Bluetooth for calls via my mobile. So it's a real shame Audi won't enable this on cars only a year or so older...can't see what the problem would be? Link to comment Share on other sites More sharing options...
Mo-S3 Posted April 25, 2016 Report Share Posted April 25, 2016 You can buy the correct update software on sd card form your parts dept if they are willing to sell it to you and update the system your self. iirc they are about £40. You will also need to change a setting in the green engineering menu in order for the sim & BT to work together. Link to comment Share on other sites More sharing options...
