AudiPartner Posted April 17, 2007 Report Share Posted April 17, 2007 What's best one is terms of whitening power but also being ok for your teeth? Anyone tried that "Blanx"? Link to comment Share on other sites More sharing options...
drpellypo Posted April 18, 2007 Report Share Posted April 18, 2007 Is't whitening toothpaste a psychosematic thing? I was watching some TV prog that said it was no different to normal toothpaste but because it was shitening you brushed better and for longer, hence producing the results of whiter teeth. I want false ones. Much easier. get MrsP some too Link to comment Share on other sites More sharing options...
CarMad Posted April 18, 2007 Report Share Posted April 18, 2007 Its not good for your teeth gums apparently, just give them a good clean or go to the dentist and get them to clean them properly for you, then keep them that way. Link to comment Share on other sites More sharing options...
Dave Posted April 18, 2007 Report Share Posted April 18, 2007 Some whitening toothpaste contains a mild bleach to stain the plaque white... trouble is that in some people it can also strip the lining of the mouth and you end up with mouth ulcers or the like. Link to comment Share on other sites More sharing options...
CarMad Posted April 18, 2007 Report Share Posted April 18, 2007 Yep, sister is a dentist and she said avoid it. However I would highly recommend getting a Sonicare toothbrush. Very very good at keep your teeth very clean have done wonders for me, no problems doing 2 mins each time and even she was impressed with the results. Link to comment Share on other sites More sharing options...
AudiPartner Posted April 18, 2007 Author Report Share Posted April 18, 2007 [ QUOTE ] However I would highly recommend getting a Sonicare toothbrush. [/ QUOTE ] Aye, had my Sonicare Elite for a couple of years now. One of the best things I own. That clean feeling you get when you've just left the dentist? Every day my friend, every day. Link to comment Share on other sites More sharing options...
Dave Posted April 18, 2007 Report Share Posted April 18, 2007 I had a sonic.. well 2 in fact, and now have the braun sonic.. has a slightly smaller head which i prefer Superb toothbrushes mind.. and i wouldn't be without mine Link to comment Share on other sites More sharing options...
CarMad Posted April 18, 2007 Report Share Posted April 18, 2007 They do it with a smaller head now as well. Link to comment Share on other sites More sharing options...
Markpaq Posted April 20, 2007 Report Share Posted April 20, 2007 [ QUOTE ] Is't whitening toothpaste a psychosematic thing? I was watching some TV prog that said it was no different to normal toothpaste but because it was shitening you brushed better and for longer, hence producing the results of whiter teeth. I want false ones. Much easier. get MrsP some too [/ QUOTE ] Link to comment Share on other sites More sharing options...
drpellypo Posted April 22, 2007 Report Share Posted April 22, 2007 Ooops! I do that all the time. Believe me, it can get you into a LOT of trouble. Link to comment Share on other sites More sharing options...
fizzbitt Posted April 23, 2007 Report Share Posted April 23, 2007 I was dubious about the whole electric tooth brushes when they cmae out and held off getting one untill a couple of years back and now i cant live without it... Best thing i did for my teeth in years! Link to comment Share on other sites More sharing options...
skifly Posted April 24, 2007 Report Share Posted April 24, 2007 so which are the best leccy toothbrushes then...? Need to invest in one based on feedback from here! Link to comment Share on other sites More sharing options...
fizzbitt Posted April 24, 2007 Report Share Posted April 24, 2007 Well essentially they all do the same job in roughly the same way. So regardless of which one you get it will be a lot better than using a manual toothbrush. IMO. Here's one similar to the one i use. I got the older version. http://www.amazon.co.uk/Braun-Oral-B-Professional-Rechargeable-Toothbrush/dp/B00008BQXU You can buy replacement heads as well.. All supermarkets have them for sale so have a gander the next time your in. Link to comment Share on other sites More sharing options...
AudiPartner Posted April 24, 2007 Author Report Share Posted April 24, 2007 Generally the Philips Sonicare ones. I have the Elite which will cost you around £100 in the likes of Boots, but can be had off ebay for nearer £50! Do it. You won't look back. Link to comment Share on other sites More sharing options...
RobK Posted April 30, 2007 Report Share Posted April 30, 2007 I find it boring when you don't have to do the brushing yourself. Seems like the 2 minutes lasts forever! Link to comment Share on other sites More sharing options...
