Bradmax57 Posted March 3, 2008 Report Share Posted March 3, 2008 Recently, my one touch shot on the drivers door has been a little hit and miss, sometimes it works sometimes it doesnt, today got in the car the interior lights were on when they should have dimmed down, now neither windows work, nor the electric mirrors, are these linked to the same fuse or relay? I cant see a fuse specifically for the windows or anything on the relays any ideas before I go and get shafted at the dealers Link to comment Share on other sites More sharing options...
shark_90 Posted March 3, 2008 Report Share Posted March 3, 2008 Do the windows switches light up when the headlights are on? Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 3, 2008 Author Report Share Posted March 3, 2008 I'll have to check that when I go back to work tomorrow as it would have been too bloody cold to drive back with window down, ill install a trial version of vagcom on lappy and see if i can see any fault codes, but ontop of that esp warning light is now on and dont work, gutted ontop of which i think my clutch is on its way out Link to comment Share on other sites More sharing options...
paul_tdi Posted March 3, 2008 Report Share Posted March 3, 2008 I had a similar problem on mine. It turned out to be a wire that runs between the door and main body had broken. Worth checking that when you lock the car that the door locks too. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 3, 2008 Author Report Share Posted March 3, 2008 [ QUOTE ] I had a similar problem on mine. It turned out to be a wire that runs between the door and main body had broken. Worth checking that when you lock the car that the door locks too. [/ QUOTE ] Will do cheers, think it locked ok but will check again tomorrow Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] Do the windows switches light up when the headlights are on? [/ QUOTE ] Drivers doesnt passengers does, passenger switch doesnt work either? Ive plugged in my vagcom didnt appear to find any faults but then again i dont really know how to use it properly as its the trial one the auto fault detect doesnt work Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] Do the windows switches light up when the headlights are on? [/ QUOTE ] If it doesnt does that give you a clue? Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 little bit of an update V]Tuesday, 04 March 2008, 14:03:43 VAG-COM Version: Release 409.1-US Control Module Part Number: 8E0 959 433 BD Component and/or Version: Komfortgerát TBF 1110 Software Coding: 06859 Work Shop Code: WSC 63351 Additional Info: Steuergerát Fahr. antwortet nicht Additional Info: 8E2959801B Tõrsteuer.BF BRM 0002 8 Faults Found: 01331 - Door Control Module: Driver Side (J386) 49-00 - No Communications 01370 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 00962 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01371 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01572 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 00956 - Key 2 35-00 - - 00532 - Shareware Version. To Decode all DTCs 37-10 - Please Register/Activate - Intermittent -------------------------------------------------------- Link to comment Share on other sites More sharing options...
PetrolDave Posted March 4, 2008 Report Share Posted March 4, 2008 Look like there's a communication problem with the module in the drivers door. Try checking the connections/connectors in the area by the door hinges. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] Look like there's a communication problem with the module in the drivers door. Try checking the connections/connectors in the area by the door hinges. [/ QUOTE ] Had a little fiddle with them but couldnt see anything obvious, might try taking the door panel off see if anythings come loose Link to comment Share on other sites More sharing options...
shark_90 Posted March 4, 2008 Report Share Posted March 4, 2008 It'll most likely be the earth wire in the rubber boot inbetween the door and the car body. I had to repair ChasDrury's for him. It had broken so cleanly it looked like someone had cut it with snips Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 just phoned audi, gits charge £114 + vat just to diagnose it Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 just felt the rubber boot, felt a snapped wire, so on further examination I guess this doesnt help! Link to comment Share on other sites More sharing options...
shark_90 Posted March 4, 2008 Report Share Posted March 4, 2008 Exactly what I was talking about. Great fun soldering it back too, good luck Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] Exactly what I was talking about. Great fun soldering it back too, good luck [/ QUOTE ] Is that the earth? probably be a hell of a lot easier if I could get the plug off Link to comment Share on other sites More sharing options...
chasdrury Posted March 4, 2008 Report Share Posted March 4, 2008 [ QUOTE ] Exactly what I was talking about. Great fun soldering it back too, good luck [/ QUOTE ] I concur... Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 ok now I know what the problem is they surely cant charge me £115+ vat to diagnose the prob wonder what they will charge to fix it Link to comment Share on other sites More sharing options...
shark_90 Posted March 4, 2008 Report Share Posted March 4, 2008 Actually looking at that again it looks like it's broken at the plug? Chas's had snapped about 1 inch down the wire. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 na the break was half way down the other bit of the brown wire is still in the door side of the boot Link to comment Share on other sites More sharing options...
chasdrury Posted March 4, 2008 Report Share Posted March 4, 2008 If you can't fix it yourself, and don't know anyone that can, I wouldn't take it to Audi! A decent auto electrician should be able to fix that for you... As mentioned, Shark did mine for me - in the dark and freezing cold it must be said!! Link to comment Share on other sites More sharing options...
shark_90 Posted March 4, 2008 Report Share Posted March 4, 2008 Ah yes, it is exactly the same then. Not too bad to do, just fiddly. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] Ah yes, it is exactly the same then. Not too bad to do, just fiddly. [/ QUOTE ] I cant get my hands in, and ive started to scratch the inside if the door trying so Im going to give up Link to comment Share on other sites More sharing options...
shark_90 Posted March 4, 2008 Report Share Posted March 4, 2008 I can't remember how I did it. I think the bubber boot will bend back enough but it's a 2 man job. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 the fun begins!!! Link to comment Share on other sites More sharing options...
paul_tdi Posted March 4, 2008 Report Share Posted March 4, 2008 Same happened on mine, it was exactly the same wire as previously mentioned! It is do-able but as Shark has commented a lot better if you get 2 on the job. I actually soldered another bit of wire on rather than just try and join the two pieces. At least this way you can fix to the exposed wire, thread back thourgh the rubber tubing, trim as required and then attach to the other end.Good luck! Link to comment Share on other sites More sharing options...
