Lussac Posted January 14, 2013 Report Share Posted January 14, 2013 (edited) Due to the size of this place and number of very thick stone walls I have to use range extenders to boost the signal around the place. Originally I had just a Linksys WRE54G extender and that was supplemented last year by 2 TP-Link extenders (recommended by Andy Bangle) which work fine. The problem is that the Macbook Pro will not see the Linksys WRE54G when it's in range, in fact it struggles to load a page at all as though there's some sort of conflict going on. If I switch the Linksys off then the pages load normally because the Macbook I think is picking up the TP-link that is further away. Now the odd thing, I recently resurrected an old Sony laptop and that connects to the Linksys WRE54G fine with signal strength excellent and fast displaying of pages. But, if I turn off the Linksys then the Sony connects to the further away TP-Link with signal strength low and slow loading of pages. This is the exact opposite of the Macbook behaviour. The other thing is that I can reach the Linksys config page from the Sony using 192.168.1.240 but when I try that with the Macbook it just hangs saying trying to connect. I have tried putting the Linksys on channel 7 whilst the TP-Links are on channel 6 but it made no difference, I just can't connect to the Linksys with the Macbook!! Edited January 14, 2013 by Lussac errm, mak it more readable! Quote Link to comment Share on other sites More sharing options...
Mac Posted January 14, 2013 Report Share Posted January 14, 2013 Punctuation please, may stop my eyes melting and enable us to help you Quote Link to comment Share on other sites More sharing options...
Andy_Bangle Posted January 14, 2013 Report Share Posted January 14, 2013 Try changing your wifi channel, detailed here: Fixed slow WIFI issue with new Macbook Pro » The Best of 32s Quote Link to comment Share on other sites More sharing options...
Lussac Posted January 14, 2013 Author Report Share Posted January 14, 2013 Hi Andy, I changed the channel on the router from 6 to 8 and the downloading is certainly faster through the TP-Link(s) which are on channel 6. But as soon I switch on the Linksys everything comes to a grinding halt on the Macbook but is flying on the Sony laptop. It certainly look as though the Macbook has a serious problem with the Linksys as my other wi-fi devices Revo internet radio and Denon internet radio both operate as normal using it as does the Sony laptop. Quote Link to comment Share on other sites More sharing options...
Andy_Bangle Posted January 14, 2013 Report Share Posted January 14, 2013 Our MBP's at work demonstrate the issue, they can grind to halt whilst the Window's laptops are fine. Boot Windows 7 on the same MBP and webpages / downloads work fine. Several times a day I have to switch between routers as webpage downloads grind to a halt, so you're not alone. Quote Link to comment Share on other sites More sharing options...
Lussac Posted January 14, 2013 Author Report Share Posted January 14, 2013 Andy, thanks for that. Thought I was going mad, I'll leave the Linksys switched off as I don't think I really need it now I've got the two TP-Links (I bought them to boost the signal to an adjacent building if you remember and now those people have moved out. I'll review the situation again if the building is occupied). Thanks again. Quote Link to comment Share on other sites More sharing options...
