Leemoss01 Posted June 6, 2013 Report Share Posted June 6, 2013 Hi i have a mk 4 golf gt tdi 130bhp car which drives very smoothly until you put on hard lock for example and when you pull out of a junction say left or right it makes a whining droning noise until you straighten the car up. Wanted to find out if it was: A) CV Joints B) Drivershafts C) Wheel Bearings D) Another problem Ideally i would like to find out what it is before i shell out a load of cash on buying parts Can anyone help on this issue?? Thanks Lee Link to comment Share on other sites More sharing options...
Chick Posted June 6, 2013 Report Share Posted June 6, 2013 could be d) a n other problem steering rack/ pump ? Link to comment Share on other sites More sharing options...
Cuprabob Posted June 6, 2013 Report Share Posted June 6, 2013 Check the power steering fluid level. Could be the PAS pump on it's way out. full lock is when it's under the most load. Link to comment Share on other sites More sharing options...
M8CKN Posted June 6, 2013 Report Share Posted June 6, 2013 Check the power steering fluid level.Could be the PAS pump on it's way out. full lock is when it's under the most load. I had a Laguna years ago with a power steering fluid leak, made a deep groaning noise on full lock when the fluid needed topping up Link to comment Share on other sites More sharing options...
cruiser647 Posted June 6, 2013 Report Share Posted June 6, 2013 That sounds like the alternator pulley bearing. Mine did that. Was an cheap fix. Link to comment Share on other sites More sharing options...
Mook Posted June 7, 2013 Report Share Posted June 7, 2013 Power steering fluid, belt, pump - check them all in that order Link to comment Share on other sites More sharing options...
Luke Posted June 7, 2013 Report Share Posted June 7, 2013 There's a whining, droning noise coming from Golf too. It's because I never bought the driver another handbag. Link to comment Share on other sites More sharing options...
