steveooo Posted October 5, 2004 Report Share Posted October 5, 2004 Hi, Please help, I have an un-modified 210BHP S3, which is suffering from serious brake fade then the ABS decides to kick and it all goes wrong.... basically my old Audi TDI had better braking on it... OK, Rant over :-) I have been told that a good option is to put Porsche 911 brake calipers, disks and pads on it, has anybody outthere sucessfully achieved this? DO i need to do anything else like brake hoses etc.... if so what parts do i need to get and does anybody know the exact Porsche part numbers so i can get it ordered. They must look awesome, Any advice welcomed, Regards Stephen Link to comment Share on other sites More sharing options...
Mollox Posted October 5, 2004 Report Share Posted October 5, 2004 You certainly can You’ll probably be looking at around £1,500 - £2k to have a new set fitted by someone like AMD or QST. Use the search function to find returns on ‘Porsche Brakes’ – there’s been loads posted Link to comment Share on other sites More sharing options...
AudiPartner Posted October 5, 2004 Report Share Posted October 5, 2004 They do look awesome. Wish I had the spare cash!! Paul's your man on this one I think. Don't think he's online at the mo (cos he hasn't yet offered to fit my lights )but it's only a matter of time!! A cheaper alternative is to go for EBC. I've already had the fronts done, getting the rears done on saturday (about £350 fitted , also Amd). Link to comment Share on other sites More sharing options...
Paul Posted October 5, 2004 Report Share Posted October 5, 2004 yes you certainly can. Im running Porsche 993 Bi turbo front brakes. [ QUOTE ] For 16/17" rims with minimum 365mm ID Porsche 993 bi-turbo 4 piston aluminium callipers, 36/44mm piston diameter Porsche 993 bi-turbo discs, 322 x 32mm vented with cast-in holes Porsche 993 bi-turbo genuine pad set for street use (75.5cm2) Kit includes custom adapters for a.m. callipers, CNC machined from highest grade steel alloy and custom brake bells for a.m. discs, CNC machined from highest grade aluminium alloy [/ QUOTE ] hats and brackets is where your get stuck as they are custom made to make the Porsche fit Audi. http://www.auto-amd.com/bigbrakes.asp Link to comment Share on other sites More sharing options...
Paul Posted October 5, 2004 Report Share Posted October 5, 2004 Forgot to add. if your running 17" Avus wheels they will fit straight on. If your running 18" RSTT 9 spokes you'll need Minimum 10mm spacers either side to clear calipers. Link to comment Share on other sites More sharing options...
steveooo Posted October 6, 2004 Author Report Share Posted October 6, 2004 Are the 17" Avus wheels the standard ones? Link to comment Share on other sites More sharing options...
steveooo Posted October 6, 2004 Author Report Share Posted October 6, 2004 hats and brackets is where your get stuck as they are custom made to make the Porsche fit Audi. What are these?, and sorry for the ignorane here. One of my freinds is a mecanic at Porshce UK and can get me the bits i need with his Staff discount which is very hany indeed. so if i get him to order For 17" AVUS rims Porsche 993 bi-turbo 4 piston aluminium callipers, 36/44mm piston diameter Porsche 993 bi-turbo discs, 322 x 32mm vented with cast-in holes Porsche 993 bi-turbo genuine pad set for street use (75.5cm2) what else do i need? As always thanks for any advice. Link to comment Share on other sites More sharing options...
Paul Posted October 6, 2004 Report Share Posted October 6, 2004 17" Avus are the standard S3 alloy. Hats... the discs are floating and are 2 piece (a rotor and a hat). the hats are the parts that bolt to the hub. Blackish inner disc bit in this picture... The Porsche ones will not fit. They are drilled to suit the audi bold pattern (5x100 PCD) Brackets... the calpiper sits on a custom made bracket to push it further out from the audi mounting points to clear the now bigger discs. I aslo chose to have the Porcshe Pad sensors fitted so the audi warnings still work (on passenger side only and costy about £16) and higher spec DOT 5.1 fluid Link to comment Share on other sites More sharing options...
Paul Posted October 6, 2004 Report Share Posted October 6, 2004 Forgemotorsport may be able to sell you the brackets and hats you need.... or you may try AmD, but they are not so keen on selling them separately from their kits, incase they get copied. you could tell them your case (ie can get discounted price sourcing them yourself) and see how it goes my brake lines are still the Audi ones. Not sure if they change the fitting in the banjo coupling to suit the Porsche or if its just a straight swap.. Link to comment Share on other sites More sharing options...
AudiPartner Posted October 6, 2004 Report Share Posted October 6, 2004 [ QUOTE ] [/ QUOTE ] I trust this photo was taken whilst you cleaning you discs Paul!! Link to comment Share on other sites More sharing options...
Paul Posted October 6, 2004 Report Share Posted October 6, 2004 yes mate. I have the wheels off every now and again for a deep clean and wax. (usually cycle them front to back at same time too, to get even tyre wear) while i am at it, i do a quick clean around the wheel arch area, including calipers and clean/flush out the holes in the discs to get rid of the brake dust build up. very easy maintenance. Link to comment Share on other sites More sharing options...
