S3_Dan Posted July 14, 2005 Report Share Posted July 14, 2005 Hi All, Im new to the forum and wondering if anyone has any advice for a problem I've got with my S3 (2000 W plate) Basically it seems like the turbo isnt working, although some days it does work. It has worked today and its been 30C so is not temperature related - but this was the first time it worked for ages. Generally the car runs ok - but without any power - the turbo doesnt cut in at all. I've had a new Air flow meter fitted about 6 months ago and currently have a problem with my "acceleration sensor" so the stealers tell me , and want £180 to fix it. As a result my ABS light and ESP light is on. Any ideas? I've read posts about the collapsed hose issue but cant see anything obvious. Any help would be appreciated as the stealers piss me off. Cheers Link to comment Share on other sites More sharing options...
Tomk Posted July 15, 2005 Report Share Posted July 15, 2005 how do you know the turbo isnt working ? it could be your throttle body, maf or coil packs, what age is the car ? Link to comment Share on other sites More sharing options...
Hopsta Posted July 15, 2005 Report Share Posted July 15, 2005 Try an independant for the work instead, all the stealer will have done it plugged in his VAG-tool and read the error off. Independant will be the same just alot cheaper ! G Link to comment Share on other sites More sharing options...
S3_Dan Posted July 15, 2005 Author Report Share Posted July 15, 2005 The car is a 2000 W plate. I've already had the MAF replaced and when that had gone before, it gave different symptoms. Currently my car runs ok (without any jerkyness etc) but just with poor performance. Its obvious the turbo isnt working, because when it does you can feel it kicking in and the performace is like an S3 should be. Could it be a collapsed hose? Link to comment Share on other sites More sharing options...
Tomk Posted July 15, 2005 Report Share Posted July 15, 2005 to be honest you dont really feel the turbo 'KIT' in you may bea ble to hear it though , id get someone with a vag.com to check the codes you are getting , Link to comment Share on other sites More sharing options...
Hopsta Posted July 15, 2005 Report Share Posted July 15, 2005 Also get some data logging done, get your requested and actual boost logged Link to comment Share on other sites More sharing options...
S3_Dan Posted July 15, 2005 Author Report Share Posted July 15, 2005 Well since the car has not been performing, I can notice the difference when the car seems to have a good day. Like I said the other day for some reason it seemed to be working ok and there was a massive difference in performance. Anyway I'll take your advice and goto someone who can get some data logging done. cheers Link to comment Share on other sites More sharing options...
Mollox Posted July 15, 2005 Report Share Posted July 15, 2005 Sounds like it might be going into limp mode - could be a number of reasons but holed hoses are often to blame for this. Lateral acceleration sensor? Bit of a weakness on the S3. Best thing to do there is get that code cleared and see if it comes back. There is next to no maintenance possible so if its misbehaving they'll just change it and charge you lots as you've seen. They're normally intermittent though so its an idea to get a feel for the frequency of the problem. Clearing it will let you spot next time it happens. Please note that while your ESP light is in it means that ESP has been disabled, likewise your ABS light so be extra careful as you're driving without these 2 safety systems as long as the lights are on. Come to a Tyresmoke meet - someone will be there with a Vag-Com and can run do the diagnosis for a packet of Cheesy Poofs instead of the £80 a dealer will want. Welcome Link to comment Share on other sites More sharing options...
S3_Dan Posted July 16, 2005 Author Report Share Posted July 16, 2005 Thanks for the info Mollox , most helpful Link to comment Share on other sites More sharing options...
Chillihead Posted July 17, 2005 Report Share Posted July 17, 2005 I have a similar issue with my A3 Q, are there any TS meets in East Scotland? Or any friendly Tyresmoke members with a vag com device? Link to comment Share on other sites More sharing options...
JoeNobody Posted July 24, 2006 Report Share Posted July 24, 2006 I've had pretty much the same problems recently. The ESP/ABS warning lights have gone off and stayed off for a few days now, but last week, they were either both on, or I was getting both the ESP and ABS kicking in when I least expected - e.g. ESP when accelerating gently in 1st, ABS under sustained braking (although not heavy/sudden). I'm happy this is ok for the timebeing, but I'm also getting the "turbo not working" thing which I think may be due to the TIP collapsing. Does anyone know how to accurately diagnose a collasping hose? Link to comment Share on other sites More sharing options...
s3ollie Posted July 24, 2006 Report Share Posted July 24, 2006 i think the turbo pipe collapsing only happens when you at 'full bore' so it should still boost when driving normally Link to comment Share on other sites More sharing options...
JoeNobody Posted July 24, 2006 Report Share Posted July 24, 2006 Sounds about right. So no way to tell when the car is stationary then? Link to comment Share on other sites More sharing options...
Mollox Posted July 24, 2006 Report Share Posted July 24, 2006 Nope, collapsing hose tends to happen at a very specific point in the rev range (c. 5,200 rpm) and under full acceleration. You notice normal acceleration and then a complete tail off and the car takes an eternity to rev beyond this point. Retrying on 1/2 throttle should see the car rev cleanly through the rev range. This also only tends to affect remapped cars Link to comment Share on other sites More sharing options...
JoeNobody Posted July 24, 2006 Report Share Posted July 24, 2006 I'm seeing it between 3.4k and 4k rpm but other than that it sounds exactly like what I have. I've got a lead on a cheap Samco TIP so hopefully that will help. Link to comment Share on other sites More sharing options...
JoeNobody Posted July 27, 2006 Report Share Posted July 27, 2006 Interestingly enough, the power issues seem to have disappeared now but I'm still having problems with the ESP and ABS. ESP/ABS either both off from start-up or no problems for ages, then either will kick when not necessary (as per my earlier post). Link to comment Share on other sites More sharing options...
JoeNobody Posted October 12, 2006 Report Share Posted October 12, 2006 Had the problems looked at when it was serviced the other day - the power issues were related to a knackered coolant (coolant temp?) sensor and the ABS/ESP issues were related to a knackered speed sensor. Link to comment Share on other sites More sharing options...
