Tomk Posted August 23, 2005 Report Share Posted August 23, 2005 ok rear squirter on teh wiper is not working , checked and water is coming out hte bottom of the tail gate so pipe must have come off ... arse is cant work out how to take the palstic surround off ! any ideas ? Link to comment Share on other sites More sharing options...
Mollox Posted August 23, 2005 Report Share Posted August 23, 2005 Sure its getting into the tailgate? There's a connection in the pipe in the inside left of the boot - behind the trim where the CD changer normally lives which is regularly a weakness. Tried that? Odd that this has happened in summer though - its normally due to water in the pipe freezing, which leads me to ask - have you checked if the jet is blocked? Link to comment Share on other sites More sharing options...
Tomk Posted August 23, 2005 Author Report Share Posted August 23, 2005 did check the jet is blocked , but i can hear the water and when i lifted the tail gate i can see it leaking out the bottom.... rear window was changed my autoglass 6 months ago so i recon its become lose as the muppets did not fit it back propperly, Link to comment Share on other sites More sharing options...
kalheer Posted August 23, 2005 Report Share Posted August 23, 2005 Mines nailed aswell... only noticed as haven't cleaned the car for nearly 2 weeks.. by order of chipsaway.. had 2 jobs done.. excellent results.. but can't clean car (i know i can always give the windscreen a wipe but who does?).. will have a check later... Link to comment Share on other sites More sharing options...
Tomk Posted August 23, 2005 Author Report Share Posted August 23, 2005 well any ideas how to get the trip off under the wiper ? Link to comment Share on other sites More sharing options...
kalheer Posted August 23, 2005 Report Share Posted August 23, 2005 NOot being mechanically minded my selfy, probably not, but will let the old man have a bash tonight... Link to comment Share on other sites More sharing options...
Mo-S3 Posted August 23, 2005 Report Share Posted August 23, 2005 hi Tom, getting the trim off can be bit of a biatch, so dont be too scared when trying it ok, What you have to do is remove the 2 screws from within the interior grab handle, the one on the tailgate. Then... you need to pry the trim away starting at the bottom of the tailgate using a long flat thick screwdriver with a piece of cloth to lever it against where it touches the painted surface. Use a torch as as you pry it outward and you will be able to see the clips and then work your way around the bottom of the whole section. The clips are very tough so you may have to give them a good jerk to release them from the body. The trim contiues uo the sides of the tailgate so you will have to do the same there but again be very carful not to damage the plastic trim. Upon refitting make sure all the clips are back in the plastic trim and not on the body. Link to comment Share on other sites More sharing options...
dq1 Posted August 24, 2005 Report Share Posted August 24, 2005 Does the new Haynes manual you said you ordered not show you how to? Link to comment Share on other sites More sharing options...
dickys3 Posted August 24, 2005 Report Share Posted August 24, 2005 Theres a link on Audi-sport.net (in the FAQ Section) but unfortunately the site is down at the moment. As soon as it is back up, I'l post the info.. Rich. Link to comment Share on other sites More sharing options...
Tomk Posted August 24, 2005 Author Report Share Posted August 24, 2005 thanks rich , as normal the haynes manual does not show anything bar , remove by pulling and one crappy pciture its raining anyway so dont need to fix it as yet but must next sunny sunday afternoon i have off ! (lets hope thats at the weeekend ) Link to comment Share on other sites More sharing options...
