Building a PC....
Mollox
£500-550
Need:
CPU
Mobo
1.5 g RAM
Bare minimum graphics card (will never be used for video or gaming - this is a dedicated sound recording/editing platform)
80 or 120gigs storage
Wireless Keyboard and Mouse
Case
Windows XP OEM (there's no value in getting 64bit XP is there?)
Processing performance and silence are the key here
Have: sound card and all the associated sound gear, external firewire drive etc
  • Replies 77
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Ok mate... Just a very quick look, and all from eBuyer, so while I might not be able to find better prices, I might be able to find better produce.
Case: £50 should get something half-decent... Or you can get a cheaper one for now and put it all in a properly silent setup later.
PSU: £65 for a 480W Modular decent brand unit, modular meaning that you don't have to have cables everywhere, plug the ones you need in and leave the rest in the box. Comes with ATX2, SATA and PCIx power attachments.
RAM: £70 gets you a high quality branded matched pair of 400mhz RAM sticks, totalling 1GB.
Mobo: Asus A8N SLi Deluxe with onboard Firewire, Gigabit LAN, SATA Raid etc etc etc... £100
CPU: £98 gets you a 90nm Athlon 64 3000+ which your motherboard can automatically overclock for you. Comes with a standard cooler and thermal pad.
Storage: £77 gets a 120GB Western Digital SATA-II, 160GB is only a few quid more, but I was working to a budget!
Keyboard/Mouse: Logitech MX700 with charging cradle for the mouse etc. £50...
Graphics: Entry level PCI-x card GeForce 6200, will still make your current setup look silly. £40.
TOTAL: £550.
I would consider the following though. - Get up to a San Diego core on the chip, it's another £100, but will run almost room temperature, so your CPU cooler can just waft silently to cool it. - Re-use your existing case for the time being, with the new PSU and a bloody great case-fan so it's nice and cool. - Later on, buy a silent case and transplant your new kit into it. 1.5GB of RAM is really awkward because your new setup will run dual channel memory, so it's best to have matched pairs. - I'd go with 1GB now and another GB later.
You know where I'm at if you want to discuss further, and if you're stuck, I'll build and install it for you, then we'll meet at Jon's for a few beers. I've got to build him a system at some point, he took one look at mine and started drooling!
So we spent bloody hours putting it together..and then taking it apart like when we suddenly realised the Zalman fan (which isn't quiet btw) needed a backplate fitting and that was a mobo out job!
Anyway, big problems. Screwed it all together very carefully and finally went to power up....except that there's nothing legible on screen...just a load of garbled nonsense. Holding down delete seems to refresh the screen as if it was going into BIOS mode but you simply can't make out anything it says frown.gif
We get a single beep and then if you leave it 7 (i think) consecutive beeps and the screen is still garbled...someone help!!! frown.gif
Right, so that means it's running an AWARD BIOS?
Award BIOS's on the latest Asus boards display the error on screen. It only resorts to beeps when it cannot access the display adpater.
1-2 beeps, Indicates a video error - any other beeps after that is RAM.
Have you ensured you've placed the RAM in the right slot? Do you have more than one stick, or is it Paired memory?
Ahh well it was just displaying a garbled mess so that might explain the beeps. It beeps once as you'd expect it to but then fires off its series of short beeps...
RAM is 2 x 512MB DDR400 and they're seated in slots A1 & B1 leaving A2 and B2 free....that's right isn't it?
What's "paired" RAM exactly?
Is multiple beeps definitely memory??
Oh yeah, here's the final spec...
AMD Athlon 64 3200+ Venice 90nm (Socket 939) - OEM (CP-131-AM) 1
£79.95
GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC)
(MY-005-GL) 1
£59.95
Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM (HD-023-SA) 1
£35.95
Zalman CNPS7700-ALCU Ultra-Quiet CPU Cooler - Retail (HS-011-ZA) 1
£22.95
1 x Antec Sonata II Piano Black Quiet Midi Tower 93403 £64.99
1 x Asus A8N SLI S939 Nvnf4sli Atx - Snd Gln 1394 U2 Fsb2000 Satar 82819 £68.98
1 x Connect3d Radeon X300SE 128mb DDR PCI-Express DVI-I TV-Out 65688 £29.78
1 x Microsoft OEM Windows XP Home Edition SP2 - 1Pk 66489 £49.40
