jimmyp Posted September 24, 2005 Report Share Posted September 24, 2005 Just a quick one chaps, has anyone had their poly belt changed yet?? As mine is getting done on friday as ive got a slight tinny rattling sound coming from the cam belt area but seemed to go away with a good blast of wd40, have been told that it's the poly belt and safe to drive. Another trip to the stealers but apart from that she is running extremly well Link to comment Share on other sites More sharing options...
mattcony Posted September 24, 2005 Report Share Posted September 24, 2005 I would have thought spraying wd40 onto a belt wasnt the best idea as its going to cause it to slip. The belt maybe too tight or too slack causing is to squeek. I too have a squeek on my belt, but only on 1st start up when its cold then it goes away till the next cold start, only had it since I had my power steering pump changed, so im guessing the tension is just not quite write. cheers matt Link to comment Share on other sites More sharing options...
Gti_Fly Posted September 24, 2005 Report Share Posted September 24, 2005 my car's poly belt has always squeeked from brand new! never thought it was worth worrying about! But seeing as it's going in on monday I'll get them to look at it Link to comment Share on other sites More sharing options...
mulkbear Posted September 24, 2005 Report Share Posted September 24, 2005 When lube spray (silicon based) is applied on a rib belt (ploy belt) is causes all dirt and water build up to disperse from the face of the pulleys and causes the belt to have a better grasp of the pulley, thus the noise becoming hushed or fade away. And i am sure the R32 don't have cam belts Link to comment Share on other sites More sharing options...
dubzter Posted September 25, 2005 Report Share Posted September 25, 2005 the R32 has cam chains AFAIK. What is the "poly" belt? alternator/water pump? Link to comment Share on other sites More sharing options...
mulkbear Posted September 25, 2005 Report Share Posted September 25, 2005 It is the belt that drives the Alternator, water pump, air con and PAS Link to comment Share on other sites More sharing options...
dubzter Posted September 25, 2005 Report Share Posted September 25, 2005 Why "poly" Link to comment Share on other sites More sharing options...
larryccf Posted September 25, 2005 Report Share Posted September 25, 2005 just a warning - WD40 is 99% kerosene and not the best compound to put on rubber and / or polymers it will cause rubber to swell (kerosene aka hydraulic fluid) would soften the paint on the older generation cars the silicone suggestion is far better and actually, while it will generate some slippage, will help seal the belts - silicone is a much friendlier compound - good for weatherstrips, etc and really a good rust or corrision prevention compound - it will not float off in water, and actually "wicks" to covering whatever surface it is on but would definitely relegate wd40 to tasks like removing rusted bolts/nuts etc Link to comment Share on other sites More sharing options...
mulkbear Posted September 25, 2005 Report Share Posted September 25, 2005 [ QUOTE ] WD40 is 99% kerosene [/ QUOTE ] I did not know that, thank god i don't use it Learn some think new every day Link to comment Share on other sites More sharing options...
Dan32 Posted September 25, 2005 Report Share Posted September 25, 2005 And its called WD40 because..........I've been led to believe 'WD' stands for war developed and 40 is either the 40th version (!) or the 40th product registered. I used WD40 on my motorcycle after washing it down. Douse the engine with it, start it up, let the WD40 get hot and start smoking, which leaves a small amount to protect the engine. Never had any problems with it but then was always washing the damn thing so probably wasn't on long enough to do any damage. Link to comment Share on other sites More sharing options...
Langers555 Posted September 26, 2005 Report Share Posted September 26, 2005 LOL war developed isn't quite correct. The WD stands for 'water displacement'. 40th stands for the 40th formula. That kerosene claim is also a load of crap. From the website: 'What does WD-40 contain? While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents. " Link to comment Share on other sites More sharing options...
Langers555 Posted September 26, 2005 Report Share Posted September 26, 2005 http://www.wd40.com/Brands/wd40_faqs.html http://www.wd40.com/AboutUs/our_history.html Link to comment Share on other sites More sharing options...
Dan32 Posted September 26, 2005 Report Share Posted September 26, 2005 I'm going to have to shoot my sources. Link to comment Share on other sites More sharing options...
s4dreamer Posted September 26, 2005 Report Share Posted September 26, 2005 Be careful or you'll get ketchup all over the kitchen! Link to comment Share on other sites More sharing options...
Mook Posted September 26, 2005 Report Share Posted September 26, 2005 [ QUOTE ] Why "poly" [/ QUOTE ] Polypropylene, a.k.a. polyprop. It's a type of malleable plastic, but the belt won't be made up of 100% polyprop. Link to comment Share on other sites More sharing options...
dubzter Posted September 26, 2005 Report Share Posted September 26, 2005 cheers thats what I thought, I had always presumed they were rubber though Link to comment Share on other sites More sharing options...
Dan32 Posted September 26, 2005 Report Share Posted September 26, 2005 [ QUOTE ] Be careful or you'll get ketchup all over the kitchen! [/ QUOTE ] Link to comment Share on other sites More sharing options...
