Akshay Posted October 23, 2005 Report Share Posted October 23, 2005 Hi, I'm looking for a high resolution image of the RS6 badge (or RS4 if same dimenions), for a design I want to re-create. Does anyone have any saved or could they take a photo of the rear boot mounted badge please? Link to comment Share on other sites More sharing options...
Riz Posted October 23, 2005 Report Share Posted October 23, 2005 You can buy these from a local dealership if its the original ones your after... if your doing something else here you go..... the front grill version Riz Link to comment Share on other sites More sharing options...
Ian_C Posted October 23, 2005 Report Share Posted October 23, 2005 Tan rule gives you the slant angle as 18.9 from the vertical. Ian Link to comment Share on other sites More sharing options...
Mac Posted October 23, 2005 Report Share Posted October 23, 2005 [ QUOTE ] Tan rule gives you the slant angle as 18.9 from the vertical. Ian [/ QUOTE ] You are indeed proper scarey. Shouldn't you be out chasing girls? Link to comment Share on other sites More sharing options...
Dave Posted October 24, 2005 Report Share Posted October 24, 2005 Riz, I think you will find that that is the rear emblem. the front is a small black little number with silver lettering. Link to comment Share on other sites More sharing options...
peterb Posted October 24, 2005 Report Share Posted October 24, 2005 [ QUOTE ] I think you will find that that is the rear emblem. the front is a small black little number with silver lettering. [/ QUOTE ] I can assure you that those dimensions are for the front emblem - I have both front and rear emblems here in my hand! The red square on the rear is ~36mm high. Yes, the front emblem is embossed on a black plastic backing, but the dimensions of the square and lettering are exactly as per Riz's diagram. Link to comment Share on other sites More sharing options...
shark_90 Posted October 24, 2005 Report Share Posted October 24, 2005 [ QUOTE ] [ QUOTE ] Tan rule gives you the slant angle as 18.9 from the vertical. Ian [/ QUOTE ] You are indeed proper scarey. Shouldn't you be out chasing girls? [/ QUOTE ] Link to comment Share on other sites More sharing options...
Dave Posted October 25, 2005 Report Share Posted October 25, 2005 [ QUOTE ] [ QUOTE ] I think you will find that that is the rear emblem. the front is a small black little number with silver lettering. [/ QUOTE ] I can assure you that those dimensions are for the front emblem - I have both front and rear emblems here in my hand! The red square on the rear is ~36mm high. Yes, the front emblem is embossed on a black plastic backing, but the dimensions of the square and lettering are exactly as per Riz's diagram. [/ QUOTE ] No.. you are right!!.. i stand corrected Link to comment Share on other sites More sharing options...
Akshay Posted October 25, 2005 Author Report Share Posted October 25, 2005 Thanks Riz - thats just what I was after! As for Tan - I still remember the old SOH-CAH-TOA trick to work out various angles!! Link to comment Share on other sites More sharing options...
Riz Posted October 25, 2005 Report Share Posted October 25, 2005 [ QUOTE ] Thanks Riz - thats just what I was after! As for Tan - I still remember the old SOH-CAH-TOA trick to work out various angles!! [/ QUOTE ]No probs.. im usually full of allsorts of useless info on cars... Riz Link to comment Share on other sites More sharing options...
Ian_C Posted November 5, 2005 Report Share Posted November 5, 2005 [ QUOTE ] [ QUOTE ] Tan rule gives you the slant angle as 18.9 from the vertical. Ian [/ QUOTE ] You are indeed proper scarey. Shouldn't you be out chasing girls? [/ QUOTE ] Hahaha, only just spotted this. Ian Link to comment Share on other sites More sharing options...
