Low beam headlights
Ecosse79
I would argue that one Ecosse. I really would. If the car was supplied to you with the lights out of kilter, then the dealer should fix the problem.
I wasn't prepared to go through the hassle, so I lined my car up in front of the garage doors, having previously sat Mrs Mook's car in front (which has excellend projector lights that are properly lined up) and measured the height from the ground to where the top edge of the low beam hit the garage door. It's how we used to do it in the good ol' days
A Phillips screwdriver and ten minutes of patience did the rest 169144-ok.gif
I thought that you can't do any manual adjustments to the headlights because of the self levelling servos's that sort out the Zenon's.
Hence the need to use Vagcom tools to take and then change angles and heights??
Anyone?
As per my post above, and Geo's.
Had my car in at the dealership getting strut mounts fitted under warranty today. They said that changing the allignment of the headlights would not be covered under warranty as it is classed as an "adjustment".
So it's our fault that the lights are set wrong?
I don't get the logic behind that. Surely if it's a legal requirement to have automatically adjusting headlights (ie increased load etc) when Xenons are involved then the system should be designed not to get out of alignment? And if it does, and it can only be adjusted by the dealer, how can it be our responsibility?
If it was my car that i had paid 20k plus for i would drag the service manager across his desk and put his VW Warranty where it hurts.
But in most cases my dealer (or any good dealer) will do it free of change under "customer good will" or make a fake warranty claim for the head lamp the be removed and refitted, and as due couse VW Warranty would pay for the head lamps to be set up.
