software RAID in windows server 2003
aal234
I have a basic two disk scsi windows 2003 server, was thinking of setting up software raid 9 no option for hardware raid on the controller) to mirror the main OS disk. Anyone had any experience good or bad of this? Or of software RAID in general?
Also, as I have to convert the basic disks to dynamic ones to mirror them, does this affect how they are backed up? I am using veritas back execs IDR feature which works ok with basic disks.
Don't touch software RAID - it eats into your processor performance. Use a PCI-66 based RAID card (if your server supports PCI-66, otherwise use PCI-33). You can pick these up from companies like www.adaptec.com or www.3ware.com for not a lot of money.
The way the disks are set up in a mirrored, RAID 1 array makes no difference to the way the data is backed up - Veritas will see it as one drive.
HTH
Not an option I'm afraid its one of these crummy 1u servers so has no expansion, which is why I am lumped with software raid only.
Any idea on the reliability of software raid? Its backed up using IDR at the moment and a full restore only takes an hour, I was just trying to figure out if it is worth running with one disk and simply restoring the image onto the spare if it dies.
Plain and simple - software RAID is better than no RAID. As long as you're not running a busy server, the CPU overhead for RAID-1 won't cause you any trouble (especially with a SCSI setup). It's helped me out on many occasions.
In your case I would say go for it - there's no real reason not to.
I hacked my installation of XP Pro to open up the RAID options. I've got 2 mirrored drives with an XP2200+ (1.8GHz) CPU. It runs ok, but can slow down sometimes. But it's not my main PC, I use it for downloads and streaming music/video/pictures to my xbox and for backups from my other 2 PCs, so I don't really notice it.
