Buck Posted April 26, 2006 Report Share Posted April 26, 2006 How do i get the stereo out of my 52 plate 320i. Is there a how to guide somewhere on the net Link to comment Share on other sites More sharing options...
Mo-S3 Posted April 26, 2006 Report Share Posted April 26, 2006 You need to pull out the climate control unit and undo the 2 screws for its holder. The climate unit is in very tight so it might be easier to start by removing the lower cubby hole and then pushing the climate out from behind. Link to comment Share on other sites More sharing options...
gizze Posted April 26, 2006 Report Share Posted April 26, 2006 If you pull the trim off above it first it is just a case of then undoing it. Start by putting a knife (with a towel wrapped round it) under the edge by the passenger side and prise it away. Slowly lift it away from the dash. It is only held in with metal pins going into holes in the dash, so gently wiggle it it away. Takes 2 minutes. Link to comment Share on other sites More sharing options...
