stevej69 Posted May 9, 2006 Report Share Posted May 9, 2006 i have a very odd issue with my 163bhp 1.8t, it starts and runs perfectly, however once up to temp, if i pull up to traffic lights for example it will idle as normal but every so often there will be a slight shudder and the revs will drop slightly and immediately return to normal. Its almost like the aircon compressor kicking in and causing monemtary strain on the engine, however i've turned off the climate control and it still happens. I remember watching a top gear episode when clarkson was driving an A8 over silly mileage on one tank of diesel and he said the engine was programmed to missfire as a warning when it was almost out of fuel, i cant see this being the case as it does it most of the time. is it normal or does anyone know what it could be? Link to comment Share on other sites More sharing options...
DanG Posted May 9, 2006 Report Share Posted May 9, 2006 Check your MAF sensor is attached to the air intake, and not loose... Its not an automatic is it? Link to comment Share on other sites More sharing options...
stevej69 Posted May 9, 2006 Author Report Share Posted May 9, 2006 no its a manual. Odd the shudder is only momentary too Link to comment Share on other sites More sharing options...
Headerss Posted May 12, 2006 Report Share Posted May 12, 2006 What if its automatic? Can you elaborate further? Link to comment Share on other sites More sharing options...
lottiefox Posted May 12, 2006 Report Share Posted May 12, 2006 My 1.8T 225 TT did exactly the same, and I know of lots of others that have done it too. Pull up at lights, idle, dip and then back up. On my newer TT it doesn't do it. Someone mentioned it might be a coil pack thats on the way out, but then other people have said its a normal characteristic of the engine.... If its the maf I would expect you to be getting some flat spots or hesitation on acceleration. is the car running as normal? Do any lights come on when it shudders? Link to comment Share on other sites More sharing options...
Headerss Posted May 12, 2006 Report Share Posted May 12, 2006 The MAF went with me due to dubai having a dusty climate. The car would be lumpy at idle and there would be flat spots, but you would easily notice the rpm moving up & down. Link to comment Share on other sites More sharing options...
stevej69 Posted May 13, 2006 Author Report Share Posted May 13, 2006 no lights and no real flat spots, although its running like off a shovel at the mo! Link to comment Share on other sites More sharing options...
bearra Posted May 15, 2006 Report Share Posted May 15, 2006 This thread is describing my only remaining problem with the cab - lumpy idle, flatspots, power dips.... Would a dodgy MAF show up at the dealers as they've had it hooked up and checked for any fault codes and I'm just being told it's a characteristic? Link to comment Share on other sites More sharing options...
Headerss Posted May 18, 2006 Report Share Posted May 18, 2006 They should be able to find out pretty easily. Its cheap anyways, approx $250. Link to comment Share on other sites More sharing options...
