spencer Posted May 11, 2006 Report Share Posted May 11, 2006 I've just bought a Mark IV R32 - I've just had chance to poke around tonight...have to say the standard air box set up look awful - it must be soooo restrictive. I've done some searching and the carbonio seems good for power but i'm concerned about its low positioning for water ingress.... I'm looking at the BMC CDA kits....are these any good? i would be interested to hear about any power results induction kits have given.....K&N is out i'm fearful of MAF problems and the kit i buy will have to be enclosed so it doesnt suck in any hot engine air... Help please??? Other than that I love the car...the full Milltek system is awesome Link to comment Share on other sites More sharing options...
pomme Posted May 12, 2006 Report Share Posted May 12, 2006 How about the EIP one as this you can get a air bypass valve so it can be lower down near the cold air. Link to comment Share on other sites More sharing options...
Mook Posted May 12, 2006 Report Share Posted May 12, 2006 Both Dan32 and I run the EIP Cold Air Intake http://www.eiptuning.com/eip/airintakes.html Make sure you buy the air bypass valve - details on the site. This sits at a similar height to the standard air box and allows air into the intake pipe if the filter (which sits behind the front bumper) is submerged. You should add between 5 and 8 bhp, depending on other mods to the car. Expect to wait 4 to 6 weeks for delivery direct from the US. Link to comment Share on other sites More sharing options...
Mwellsgarage Posted May 12, 2006 Report Share Posted May 12, 2006 BMC kits are the way to go i have had one on my polo GTI and my mate has had one on his TT and golf gti, throttle response is sharpened up and it does seem to pull from lower down the rev range now, not sure how much bhp is increased possibly 4 or 5 Link to comment Share on other sites More sharing options...
kaypee Posted May 12, 2006 Report Share Posted May 12, 2006 I run the EIP Cold Air Intake too and it rocks the house The whole thing from how well put together the kit is through the instructional video on how to fit it through how well it fits to the car to how great it sounds ... top notch piece of kit! Link to comment Share on other sites More sharing options...
BigMeanBob Posted May 12, 2006 Report Share Posted May 12, 2006 Slider, All of the kits generally end up with the intake in more or less the same position. With the BMC kit, the only difference is that the filter is in the engine bay as opposed to on the end of the intake. The hose still sits down at more or less the same level and would proabably be as likely to suck in water. Was also under the impression that the BMC kit didn't give quite as good a result as some of the others (remembering that that might be as little as 1-2 bhp on a 250bhp car though). I had the Carbonio pre SC and it gave a great result. If you search back through my threads you'll see the before and after dynos on here....result was pretty good, plus the thing sounded beautiful. In all honesty though, I think the majority of the intakes give a very similar result. They are all as likely as each other to screw your MAF in my opinion. b0b Link to comment Share on other sites More sharing options...
Mook Posted May 15, 2006 Report Share Posted May 15, 2006 [ QUOTE ] In all honesty though, I think the majority of the intakes give a very similar result. They are all as likely as each other to screw your MAF in my opinion. [/ QUOTE ] Interesting comment Bob - the single biggest problem with MAFs getting screwed is when people over-oil their K&N panel air filters. I've run the EIP CAI on my car for over 20K miles now and have never had a problem - it sits behind the bumper and the MAF sits in pretty much the same position as when using a stock air box. I would have thought the s/charger conversion would cause some concern, given that the hi-flow air filter is only just below the MAF, just under the s/charger - or have you not had any problems? Link to comment Share on other sites More sharing options...
BigMeanBob Posted May 15, 2006 Report Share Posted May 15, 2006 Seems to be running fine at the moment Mook. I agree that there is a good chance that it will fail quicker with the forced induction. I think the MAFs can just be very fickle in general... b0b Link to comment Share on other sites More sharing options...
Mook Posted May 16, 2006 Report Share Posted May 16, 2006 [ QUOTE ] I think the MAFs can just be very fickle in general... [/ QUOTE ] Got to agree with you on that one Link to comment Share on other sites More sharing options...
niikme Posted May 16, 2006 Report Share Posted May 16, 2006 I am also a very happy bunny! Picked up my MK4 on Friday.... WOW What a car!! Have to agree on the intake, I had a word with awesome over the weekend who rate the carbonio but I am equally concerned by the MAF sensor stuff and the chance of it sucking up liquid into the engine - Expensive mistake to make. Sorry for hijacking thread but two questions: 1. The standard exhaust (I think) sounds fantastic, but the vast of majority of peeps upgrade to the Milltek. Is this in improvement or just different? I do not want to lose the boom at 2000 rpm. So resonated milltek or non resonated ? I also do not want roar at 80 mph on the motorway! Your opinions are appreciated pls! 2. The honeycomb grill on the right (looking towards car) has a few sections punched out and there is a device behind it with a hole in it. What the hell is it ?! Thanks !!!!!! Kristian, proud silver R32 owner. The best ever! Link to comment Share on other sites More sharing options...
Mook Posted May 16, 2006 Report Share Posted May 16, 2006 Welcome to Tyresmoke Niikme I posted a thread a couple of months ago, entitled Everything you wanted to know about Milltek - hopefully this will answer some of your questions, including increased sound and performance. The sensor behind the nearside front grill is the external temperature sensor. HTH Link to comment Share on other sites More sharing options...
v6tas Posted May 16, 2006 Report Share Posted May 16, 2006 Am i the only one who actually likes the motorway boom Link to comment Share on other sites More sharing options...
RedRobin Posted May 16, 2006 Report Share Posted May 16, 2006 [ QUOTE ] Am i the only one who actually likes the motorway boom [/ QUOTE ] ....I don't think you are the only one. I quite like that slightly louder constant note when you hold about 3,200 revs (in the GTI with Non-Resonated Millteks). It's more of a drone than a boom and it's not over intrusive. I've never quite understood what is meant by exhaust "boom" unless on a boy-racer baked-bean can system. Link to comment Share on other sites More sharing options...
colly Posted May 16, 2006 Report Share Posted May 16, 2006 [ QUOTE ] I had the Carbonio pre SC and it gave a great result. If you search back through my threads you'll see the before and after dynos on here....result was pretty good, plus the thing sounded beautiful [/ QUOTE ] Glad to see somebody else thinks the Carbonio is a good filter. Simply awesome sound. Also if its got a form filter on the end instead of a stainless one I would worry about the MAF getting water \ dirt on it. Once I had bought the Carbonio I had to remove the filter it came with and replace with a stainless steel protected one - this stops all the MAF trouble, 12month hassle free so far. Link to comment Share on other sites More sharing options...
Splendub Posted May 16, 2006 Report Share Posted May 16, 2006 Hey Niikme, Picked up my Mk4 R on friday as well actually. Got the guy to stay up till half 9 coz i wouldn wait any longer. I think if im not mistaken that behind the honeycomb where those holes are puched out is the temperature sensor to tell you on the dashboard the temp outside. Link to comment Share on other sites More sharing options...
niikme Posted May 18, 2006 Report Share Posted May 18, 2006 tspar, redrobin, i LOVE the boom. I dont want to lose it. Thats the point of my question. Not sure 'boom' is the right term either, its more of a low bassy, echoey noise of gasses bouncing about..... Ive read opinions that the resonated millteks reduce this noise - i would be unimpressed if this is the case!!! Splendub, congratulations, awesome piece of engineering IMO! I have wanted one for ages! I will let you know how I get on with the milltek but Mook seems to understand a lot about them and going by his advice the milltek is gonna be awesome!! Link to comment Share on other sites More sharing options...
niikme Posted May 18, 2006 Report Share Posted May 18, 2006 ALSO, a lot of owners on the r32register claim a TDH upgrade? Anyone know what TDH stands for?? Its bugging the hell out of me! Secondly, as part of my negotiation i got a discount based on the fact that the tyres have little life left in them. What should I be replacing them with for all round, all weather use ? Link to comment Share on other sites More sharing options...
Mook Posted May 18, 2006 Report Share Posted May 18, 2006 The resonated Milltek (i.e. with a centre silencer) is louder than the standard exhaust from outside the car. The design of the rear silencer means that the horrendous boom inside the car that the Mk4 R32 produces at around 2K rpm with the standard exhaust is eliminated. It all depends if you want noise in the car, or you want to stick your head out of the window to hear your exhaust On an unmodified R32, the straight-through Milltek centre section (which is installed in place of the Milltek centre silencer) doesn't increase the noise too much, but it is louder. I ran the straight-through centre section on my Stage 4 for about a month and had to take it off - it was just too loud for every day use. Something to do with arriving at a hotel in Nottingham, and everyone, everyone turned around to see what the feck it was. Unwanted attention isn't for me, but some people like it. Niikme, I would suggest you try the Milltek with the centre silencer, then if you want it louder, get the straight-through - it's only about £130 extra. Link to comment Share on other sites More sharing options...
Mook Posted May 18, 2006 Report Share Posted May 18, 2006 [ QUOTE ] TDH [/ QUOTE ] Which register? I'll take a look. [ QUOTE ] What should I be replacing them with for all round, all weather use ? [/ QUOTE ] Michelin Pilot Sport 2 or Goodyear Eagle F1 seem to be the flavour of most people on TsN. Link to comment Share on other sites More sharing options...
Mook Posted May 18, 2006 Report Share Posted May 18, 2006 Ignore that - Tax Disk Holder Link to comment Share on other sites More sharing options...
niikme Posted May 18, 2006 Report Share Posted May 18, 2006 http://www.r32register.co.uk/register.php Tax Disc Holder, OMG. Now why would anyone want to quote that as a modification !!!!!!! haha Link to comment Share on other sites More sharing options...
niikme Posted May 18, 2006 Report Share Posted May 18, 2006 Mook, im having a nightmare! a chap just contacted me and said he wasted 500+ on milltek stuff. the resonated is far quieter from inside the car than the stock, and the non resonated wakes the neighbours! he is now with the stock again. its kind of prompted a question, there is a comparison video on the milltek website - are these non resonated (straight thru) in your opinion ? Cheers Kris Link to comment Share on other sites More sharing options...
Mook Posted May 18, 2006 Report Share Posted May 18, 2006 No, they're silenced. You've gone the whole way down the road of thinking about it for too long now. Just buy the exhaust with the silenced centre section and be done with it. You won't be disappointed Link to comment Share on other sites More sharing options...
pomme Posted May 18, 2006 Report Share Posted May 18, 2006 Yeah best get the simenced as i also had it ST and changed it in the end to silenced. And as Mook says you wont be disapointed Link to comment Share on other sites More sharing options...
Skidmark Posted May 18, 2006 Report Share Posted May 18, 2006 [ QUOTE ] Yeah best get the simenced as i also had it ST and changed it in the end to silenced. And as Mook says you wont be disapointed [/ QUOTE ] same here.....it's 'the dogs...' Link to comment Share on other sites More sharing options...
