Sponge Posted May 13, 2006 Report Share Posted May 13, 2006 Does anyone know if retro-fitting the front parking sensors, when you already have the rears, is possible? I fitted front and rear parking sensors to my dad's car and it was a simple case of fitting and routing the cables from the sensors to the control box. I was wondering if with my car already having the rear sensors, would it be a simple case of getting the fronts and connecting them to some sort of control unit? A unit that already has the rears connected and empty sockets for the fronts to hook up to. Or would that be wishful thinking? Link to comment Share on other sites More sharing options...
SPLiiX Posted May 13, 2006 Report Share Posted May 13, 2006 Good question and sorry I can not tell you, but... I have front and rear and I have a button on the dash beside the hazard warning button, to manually switch it on if I do not select reverse. I take it that there is no button on the dash to switch on or off manually if you have the rear park control only. In my mothers A3 Sportback she has rear but not front and there is no button on the dash. Also it was not an option front ones on the A3???? So you would need to buy the button and blank for the dash if you ask me. Hope that has helped a little. Link to comment Share on other sites More sharing options...
UBM Posted May 13, 2006 Report Share Posted May 13, 2006 Sponge - I think it is possible for sure, but I know you need the switch on/off button somewhere to mount on the dash. It may just plug into the same control box. I know the rear park system I had fixed only had enough sensors for the rear park! Link to comment Share on other sites More sharing options...
Chav Posted May 13, 2006 Report Share Posted May 13, 2006 The switch isn't essential of course - the range is only a few feet, so the beeping would only annoy you if you were VERY close to the car infront! Link to comment Share on other sites More sharing options...
SPLiiX Posted May 14, 2006 Report Share Posted May 14, 2006 Chav, the Revers park control switches itself off after 10miles an hour and does not go on again until I either switch it on manually or select reverse. So he may not need the switch but would have to select reverse before going forward into a space. Link to comment Share on other sites More sharing options...
Sponge Posted May 15, 2006 Author Report Share Posted May 15, 2006 Surely the front sensors wouldn't be on the same circuit as the rears? The rears activate when you select reverse (I have no separate switch) and the fronts will activate when you press a button (as you shouldn't really have them on all the time). So, if you remove the button/switch from the front sensor circuit, they'll be on all the time. I imagine this would only become an issue if you're permanently driving 2ft from someones bumper. Or has Audi done it some more complicated way? Link to comment Share on other sites More sharing options...
bearra Posted May 15, 2006 Report Share Posted May 15, 2006 My front sensors switch on if you use reverse automatically the same as the rears which is great when parallel parking. Link to comment Share on other sites More sharing options...
Nelson_R32 Posted May 15, 2006 Report Share Posted May 15, 2006 You'll need a new control unit, new sensors, wiring loom for the front bumper and allot of careful drilling. Would be pretty expensive. Or alterantively you could give £30 to you local driving instructor and they'll teach you how to park properly (flame suit on! ) Link to comment Share on other sites More sharing options...
Paul Posted May 15, 2006 Report Share Posted May 15, 2006 I prefer the idea of this. http://www.ukspeedtraps.co.uk/laserpropark.htm for those front parking mishaps. very temped to get one. Link to comment Share on other sites More sharing options...
Sponge Posted May 15, 2006 Author Report Share Posted May 15, 2006 [ QUOTE ] You'll need a new control unit, new sensors, wiring loom for the front bumper and allot of careful drilling. Would be pretty expensive. Or alterantively you could give £30 to you local driving instructor and they'll teach you how to park properly (flame suit on! ) [/ QUOTE ] The sensors don't come with their own wiring? A new control box? The gits make two different boxes depending on whether you spec just rears, compared to both front and rear? Feckers! As for the driving comment. The sensors are quite obviously for my wife. Link to comment Share on other sites More sharing options...
UBM Posted May 15, 2006 Report Share Posted May 15, 2006 [quote As for the driving comment. The sensors are quite obviously for my wife. [/ QUOTE ] Link to comment Share on other sites More sharing options...
