Romaldho Posted May 24, 2006 Report Share Posted May 24, 2006 Hello all I have a year old 320CD Sport Convertible which I dropped off at a dealership today as there was excess noise in the cabin. They have informed me that BOTH rear wheel bearings need replacing. The car has only done 21000 miles. Has anyone else had these problems as this seems unusual? Also, the dealership reckons both rear tyres need replacing. Is 21000 miles what you would expect from rear tyres? Sounds quite low to me as the majority of them have been on motorways. Cheers.... Link to comment Share on other sites More sharing options...
Snail Posted May 26, 2006 Report Share Posted May 26, 2006 Hi Dude. What size wheels have you got? Larger wheels tend to kill bearings quicker, my last set of bearings in my A4 (not exactly a beemer, but you get the idea) lasted about 15k with 18s Link to comment Share on other sites More sharing options...
kerbside Posted May 28, 2006 Report Share Posted May 28, 2006 Snail is right. Big alloys play havoc with wheel bearings. If the wheels are much bigger than the standard ones they can affect the suspension geometry which is probably what caused the premature wear. When you get new rubber get them to check the 4 wheel alignment with the new tyres otherwise your car will do the same to the new ones. Link to comment Share on other sites More sharing options...
A2TDI Posted July 1, 2006 Report Share Posted July 1, 2006 I have had 2 new WB's on the N/S/R on my E46 Coupe. Link to comment Share on other sites More sharing options...
PeterS Posted July 1, 2006 Report Share Posted July 1, 2006 Welcome! As your car is only a year or so old, I'd expect the wheel bearings to be covered under warranty, unless you've changed to non standard wheels. If you have, as others have said, this could cause additional wear on the bearings and so BMW would be unlikely to pick up the tab. As for tyres, 21,000 miles doesn't seem that bad to me for the rears; the ones on my 5 are over half worn at 11,000 miles... HTH Peter Link to comment Share on other sites More sharing options...
