Retrofit Automatic Headlights B7
sportypants
The light sensor is in the (auto dimming) interior mirror, and comes with auto wipers on the B7. So you would have to change the interior mirror for sure. Are the wires in place from the interior miror to carry the light/dark and wet/dry signals to the convenience ECU? (I think it might be CAN)
Not sure if the convenience ECU version would need changing either (in the same way that there are at least two versions of the SCSM - on that is cruise & MFSW ready, and on ethat isn't)?
Isn't it just another gadget you can live without? Fair enough if you just like to tinker/modify (I know the feeling well!) but I've used automatic wipers/lights before and tbh I preferred to manually use them - they never worked perfectly for me.
Just like with sat-nav, I'm just as happy with TomTom as RNS-E.
Maybe I'm getting old, but when my auto wipers broke, it was the end of my world... but then again it also took out the intermittent wiper control so I had to keep switching between off and normal wipers, which was a pain. Then my auto lights failed and I was at deaths door.
Fortunately they are all working again now and the sun is shining once more.
I'm with craigyb - when I had an A4 without auto headlights it was a real pain having to remember to turn them off (knowing when to turn them on wasn't a problem smile.gif )
And having the auto wipers now is great, I just leave the wipers permanently in the auto position and they just do their stuff.
I had auto lights on my lexus as std(now gone frown.gif ) and I really miss them already (only had the car 2 days). I used to jibe the missus something rotten when in her fiesta about the laborious task of manually having to turn the lights on and off. This would be a great retrofit for me but I recon it'll be mega ££££. I'll just have to get used to manual lights again
How do you deal with the trauma of moving the steering wheel?
Christ, "auto lights" - all you have to do is rotate the switch. Why not just turn them on all the time - make it part of the startup procedure.
With bi-xenons you get DRL's so you don't even have to do that!
There's a switch which you set permanently for DRL's on or off. Mine are OFF - I don't want to look like a Volvo jump.gif
I have my DRL's on all the time. Used to be a biker and i think it makes me more visible and therefor less at risk 169144-ok.gif
