Rayza Posted October 10, 2006 Report Share Posted October 10, 2006 Yesterday I went to fill up my washer bottle and noticed the engine bay was very warm/hot. This was approx 1.5 hrs after my drive home from work (45 mins and 35 miles). Not noticed this on any other car I have owned. The engine temp gauge is fine so I can only assume it is the FSI engine. Is this normal and has anyone else noticed this? Or am I reading too much into this? Link to comment Share on other sites More sharing options...
DHA Posted October 10, 2006 Report Share Posted October 10, 2006 Probably readint too much into it. The turbo gets very hot as does the engine block itself. With the bonet closed there is not much oppurtunity to dissipate heat. As long as the engine temp gauge is showing normal when you drive then I wouldn't worry too much. Link to comment Share on other sites More sharing options...
Rayza Posted October 10, 2006 Author Report Share Posted October 10, 2006 Thought as much, thanks DHA. Link to comment Share on other sites More sharing options...
petsy Posted October 10, 2006 Report Share Posted October 10, 2006 it's normal as I see the same sort of behaviour. Link to comment Share on other sites More sharing options...
RedRobin Posted October 10, 2006 Report Share Posted October 10, 2006 The TFSI engine is known to run very hot compared with other engines. It warms up very quickly too I've noticed. Link to comment Share on other sites More sharing options...
Mollox Posted October 10, 2006 Report Share Posted October 10, 2006 You have a turbo! You'd be amazed at the temperatures these things get up to. Next time you're out for a drive at night, pop the hood when you get home - I wouldn't be surprised if you see a red glow from the Turbo after you've switched off. The S3, even in standard form, gives off immense heat. I remember when it was new and I drove it in shorts for the first time - stood by the drivers door the heat coming out of the the bottom of the car was incredible - I thought I was going to lose my hairs. In fact you won't believe the temperature at all. I once was curious and logged my exhaust gas temperature with Vag-Com.... Anyone want to hazard a guess? (Its the engine exhaust gas, not that which comes out of the pipe! ) Link to comment Share on other sites More sharing options...
rs32 Posted October 10, 2006 Report Share Posted October 10, 2006 somewhere between 500 and 600 degrees C ? Link to comment Share on other sites More sharing options...
Daz Posted October 10, 2006 Report Share Posted October 10, 2006 [ QUOTE ] Anyone want to hazard a guess? [/ QUOTE ] I know Link to comment Share on other sites More sharing options...
Mollox Posted October 10, 2006 Report Share Posted October 10, 2006 [ QUOTE ] [ QUOTE ] Anyone want to hazard a guess? [/ QUOTE ] I know [/ QUOTE ] Good, now keep quiet, there's a good Daz Link to comment Share on other sites More sharing options...
DHA Posted October 10, 2006 Report Share Posted October 10, 2006 But mollox the GTI emits special heat Link to comment Share on other sites More sharing options...
Mollox Posted October 10, 2006 Report Share Posted October 10, 2006 Its all hot air at the end of the day, isn't it? Link to comment Share on other sites More sharing options...
Daz Posted October 10, 2006 Report Share Posted October 10, 2006 [ QUOTE ] [ QUOTE ] [ QUOTE ] Anyone want to hazard a guess? [/ QUOTE ] I know [/ QUOTE ] Good, now keep quiet, there's a good Daz [/ QUOTE ] And I've just found the spreadsheet we logged to too Link to comment Share on other sites More sharing options...
Mollox Posted October 10, 2006 Report Share Posted October 10, 2006 It doesn't really work if no one guesses Link to comment Share on other sites More sharing options...
Muppetboy Posted October 10, 2006 Report Share Posted October 10, 2006 400 C? Link to comment Share on other sites More sharing options...
seventyseven Posted October 10, 2006 Report Share Posted October 10, 2006 'Bout 550? Altho my mkv's on order,was wondering re this as both my 16 valve mk2 & 8 valve mk3 both seemed to chuck out loads of heat if you were anywhere near the bonnet,even tho' the gauges were fine. Not technically gifted(''hey man,I only drive 'em...'')so I'll just put it down as a Golf thing!! Link to comment Share on other sites More sharing options...
Mollox Posted October 10, 2006 Report Share Posted October 10, 2006 Ok then....none of you were anywhere near... It logged (IIRC) 450 deg C at IDLE just after start-up and......955 deg C peak on a spirited quick run!! Nine hundred and Fifty-Five Degrees Celsius!!!!! And then you wonder why its a little hot under the bonnet? Link to comment Share on other sites More sharing options...
rs32 Posted October 10, 2006 Report Share Posted October 10, 2006 perhaps explains why turbos melt if the boost and fuelling are upped lots Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted October 10, 2006 Report Share Posted October 10, 2006 That's hot! Wouldn't want to get a petrol leak in that area would you? Link to comment Share on other sites More sharing options...
DHA Posted October 10, 2006 Report Share Posted October 10, 2006 Boxsters get very very hot, not much space to let heat out from the air outlet on the side. If you turned the car off when you parked it the fan would always come on when you restarted even after a few hours. Link to comment Share on other sites More sharing options...
