bhx90 Posted August 1, 2007 Report Share Posted August 1, 2007 Hi, I'm toying with the idea of a RNS-E retrofit for my 05 Audi A3 Sportsback. I have checked out plenty of forums on the subject including navplus.us and I pretty sure I could cope with the install as I have the double din non-Bose Symphony head unit and most sites provide a comprehensive parts list. I do have some questions unanswered such as where to purchase the RNS-E from, where position the GPS receiver and what can I add to it - bluetooth phone, TV etc. Or should I get it fitted by one of the retrofit gurus - Craigyb and PetrolDave come to mind as I read some great feedback on them. I'm based in the Midlands but always happy to give the car a good run. Any advice would be welcome. Cheers Phil Link to comment Share on other sites More sharing options...
mb Posted August 1, 2007 Report Share Posted August 1, 2007 I think it depends how much of a learning experience/hassle you want. If you are thinking of fitting it yourself then I am sure you have the necessary skills with some instructions to do so & get it all working. I fitted a VW MFD to my car & it needed several "goes" to get it right & all working as my car came with an upgraded stereo which made the install more complicated. I have subsequently added blue tooth (basic Nokia variety) & integrated it (mute/play through speakers) with the sat-nav, I know the Audi ones can have proper BT integration. If you want a one time install with no hassle & support if there is ever a problem as well as your car being dealt with by someone who has seen it all before & will know how to cut the dash etc. where necessary then get one of the experts to install it & make your life simple. If you enjoy projects like this, have the time & patience to get things right & want to learn more about your car then install it yourself - both are different but good choices ! Link to comment Share on other sites More sharing options...
the911sc Posted August 1, 2007 Report Share Posted August 1, 2007 I did mine diy in the RS. Not 'easy' but straightforward enough. If you have symphony already, its much easier; if not then think carefully.You will also need VAG com (full version with the proper lead) to code it correctly. Link to comment Share on other sites More sharing options...
PetrolDave Posted August 2, 2007 Report Share Posted August 2, 2007 If you have a Symphony or other double DIN radio then there are no mechanical modifications at all. If you get an RNS-E plus the correct adapter lead (plus antenna adapter and GPS antenna) then the actual install takes less than an hour. You need 4 radio removal tools and VAG-COM - since you have an 8P A3 you need a CAN lead for VAG-COM (micro-CAN, HEX-COM+CAN or HEX-USB+CAN), and since you'll need to recode the CAN gateway you'll need VAG-COM version 6xx or later to get the long coding helper. After the install you should expect to get a ZF antenna error code on the RNS-E - this is because the antenna wiring in the car is different with a factory installed RNS-E. Link to comment Share on other sites More sharing options...
bhx90 Posted August 5, 2007 Author Report Share Posted August 5, 2007 Thanks for all the advice. Where is the best place to purchase all the relevant parts and the RNS-E? Cheers Link to comment Share on other sites More sharing options...
PetrolDave Posted August 6, 2007 Report Share Posted August 6, 2007 Look over on www.navplus.us there's several European sellers advertise there. Link to comment Share on other sites More sharing options...
