Andy_Bangle Posted November 25, 2013 Report Share Posted November 25, 2013 (edited) Renault F1 V8 engine on Mark Webber's car being fired up for the last time, with the limiter off! 22,000 rpm is achieved, I think Renault were just "grenading" the engines .. Edited November 25, 2013 by Andy_Bangle 1 Link to comment Share on other sites More sharing options...
Andy_Bangle Posted November 25, 2013 Author Report Share Posted November 25, 2013 (edited) Caterham did the same thing, but the video has been taken down (Reason video was taken was because the teams aren't allowed to film int he pits/track) https://twitter.com/MyCaterhamF1 https://twitter.com/ThomasSenecal/status/404707084907716608/photo/1 Edited November 25, 2013 by Andy_Bangle Link to comment Share on other sites More sharing options...
NewNiceMrMe Posted November 25, 2013 Report Share Posted November 25, 2013 Ouch. Ears. Link to comment Share on other sites More sharing options...
Rachel Posted November 25, 2013 Report Share Posted November 25, 2013 Yellow hot exhausts and blue flames, just what every (road) car needs. Link to comment Share on other sites More sharing options...
Andrew Posted November 25, 2013 Report Share Posted November 25, 2013 What are the tolerances in normal road cars? For example, how many rpm over 8,300 would my BM do before (I guess) a piston let go. I'm not about to conduct an experiment BTW ... Link to comment Share on other sites More sharing options...
DanG Posted November 25, 2013 Report Share Posted November 25, 2013 This is quite a common problem with the early 911 engines..... sigh. With the vagueness of the original gearboxes is it VERY easy to hit 1st from 4th ont he downshift, sending the revs well past the red line. Most people who take their cars seriously upgrade the shifter to a Wevo to stop this from happening. I have also seen cars where the throttle cable has snapped, dropped down and been picked up by a drive shaft and so held wide open..... Anyway, what happens is that the valves become the weak point and because the cams are spinning so fast, the valves 'float', i.e. both become fully open at all times as the valve spring cannot operate fast enough to close them, which usually ends up with piston impacting valve, valve head or heads breaking off and becoming even bigger and inflexible objects in the combustion chamber, this then mashes the head, and piston and usually results in a cracked or completely severed con rod, which in turn ends up going through the bottom of the case or certainly belting about on the inside of the case enough to destroy it forever. As all 6 cylinders are generally doing this, there are usually a lot of bent valves etc. RPM to achieve valve float varies with the weight of the valves and the strength of the spring used to ensure it follows the cam lobe. The last of the 12 valve 911 engines, the 3.2's, had the heaviest and largest valves so suffered more than later models where valves were doubled up to 4 per cylinder and made of stainless steel or even titanium. High revving engines, expensive to build, even more so when they let go.... On modern cars everything is lightened, and the valves on your M3 are probably very light and have a large valve spring to get them back up into the head, given the red line is already 8,300, but wont be immune to this type of issue at a certain level.... 1 Link to comment Share on other sites More sharing options...
Dave Posted November 25, 2013 Report Share Posted November 25, 2013 Makes you wonder if Renault had something in those engines that they didn't want discovered?? Link to comment Share on other sites More sharing options...
bazza_g Posted November 25, 2013 Report Share Posted November 25, 2013 Renault F1 V8 engine on Mark Webber's car being fired up for the last time, with the limiter off! 22,000 rpm is achieved, I think Renault were just "grenading" the engines .. The guy talking to Webber from 45 seconds onwards is my ex wife's uncle Kenny, he loves a bit of camera time and has had plenty this season! 1 Link to comment Share on other sites More sharing options...
Cuprabob Posted November 25, 2013 Report Share Posted November 25, 2013 The guy talking to Webber from 45 seconds onwards is my ex wife's uncle Kenny, he loves a bit of camera time and has had plenty this season! He got interviewed a few races back. I think it was just after Vettel had won the championship. I recognised him from one of your previous posts. 1 Link to comment Share on other sites More sharing options...
Andrew Posted November 25, 2013 Report Share Posted November 25, 2013 Good description Dan - I can follow that perfectly. Link to comment Share on other sites More sharing options...
Ian_C Posted November 25, 2013 Report Share Posted November 25, 2013 The guy talking to Webber from 45 seconds onwards is my ex wife's uncle Kenny, he loves a bit of camera time and has had plenty this season! Yeah, most notably on the F1 Forum the race Red Bull clinched both drivers and constructors, Jordan had a quick interview with him. Link to comment Share on other sites More sharing options...
patently Posted November 25, 2013 Report Share Posted November 25, 2013 I love the fact that whatever volume your PC speakers are set to, it's too low to reflect the sound as recorded... Link to comment Share on other sites More sharing options...
Andy_Bangle Posted November 25, 2013 Author Report Share Posted November 25, 2013 3 Link to comment Share on other sites More sharing options...
Scotty Posted November 25, 2013 Report Share Posted November 25, 2013 I'm amazed that with no airflow etc and being given that it didn't just give up. I know they're tested beyond their operation limits but that's pretty impressive. Oh and I wouldn't have been that fecking close to it! Link to comment Share on other sites More sharing options...
Andy_Bangle Posted November 26, 2013 Author Report Share Posted November 26, 2013 (edited) Checkout this vid of the Caterham: http://distilleryvesper5-9.ak.instagram.com/713e539e554711e3837d12ed59f8056e_101.mp4 Another video (different angle): http://webcache.googleusercontent.com/search?&rls=en&q=cache:http://www.viddy.com/video/ab0db6b8-d150-439d-bb8c-3b11be23e82f&ie=UTF-8&oe=UTF-8 Edited November 26, 2013 by Andy_Bangle Link to comment Share on other sites More sharing options...
Andy_Bangle Posted November 26, 2013 Author Report Share Posted November 26, 2013 Link to comment Share on other sites More sharing options...
CarMad Posted November 26, 2013 Report Share Posted November 26, 2013 Good work, I wonder why they do this?!?! Link to comment Share on other sites More sharing options...
patently Posted November 26, 2013 Report Share Posted November 26, 2013 My guess? (a) fun (b) YouTube hits © they probably get some useful data on the behaviour of various engine parts. Note that on Webber's car they seemed to be working up in stages, which would give them the most data. Link to comment Share on other sites More sharing options...
Andy_Bangle Posted November 27, 2013 Author Report Share Posted November 27, 2013 Good work, I wonder why they do this?!?! Publicity, fun plus they don't need the engines need any more (bye-bye V8's). Each car has 8 engines for the season so trying to blow one up isn't a biggy Link to comment Share on other sites More sharing options...
