russellfray Posted September 4, 2004 Report Share Posted September 4, 2004 Does anybody know what the stuff is called that you use to hide cabling that looks like a vacuum cleaner hose? Basically it's a flexible hose that can be stretched like a concertina (sp?). I want some in black, fairly thin, to cover the metal posts on my car headrests after I've fitted some screens so i can run the cables. I don't want the stuff that has a "split" down one side, but rather stuff that is solid so the cables have to be run down the middle. I've searched for conduit, hosing, trunking, but just can't think of what it's called If someone can come up with not only the name of the stuff but a website in the UK that sells it, I would be very grateful!!! Link to comment Share on other sites More sharing options...
Scotty Posted September 4, 2004 Report Share Posted September 4, 2004 I know it;s not what you're searching for but have you considered heat shrink tubing? Link to comment Share on other sites More sharing options...
russellfray Posted September 4, 2004 Author Report Share Posted September 4, 2004 The problem is that the headrests still need to be able to move up and down... so i need something flexible (and springy) so that as the headrests move up, it will spring out and cover the whole tube - but when the headrests go down, it will compress. Link to comment Share on other sites More sharing options...
Chav Posted September 4, 2004 Report Share Posted September 4, 2004 conduit/sleeving/tubing me thinks... maplin.co.uk sell flexible conduit in 13.8 or 17.2mm inner bore as well as heat-shrinkable sleeving/tubing in the cable and accessories section. Link to comment Share on other sites More sharing options...
Sven Posted September 4, 2004 Report Share Posted September 4, 2004 Have you checked whether the metal 'posts' are hollow? That's usually where they hide the cable for an LCD... Link to comment Share on other sites More sharing options...
russellfray Posted September 4, 2004 Author Report Share Posted September 4, 2004 [ QUOTE ] Have you checked whether the metal 'posts' are hollow? That's usually where they hide the cable for an LCD... [/ QUOTE ] I don't know how to get the headrests out yet, I have posted the question in the A4 board but no replies yet - if they are hollow then that would be excellent, but I know previous cars I've had (Rover/Jaguar) were solid and not hollow. Link to comment Share on other sites More sharing options...
russellfray Posted September 4, 2004 Author Report Share Posted September 4, 2004 [ QUOTE ] conduit/sleeving/tubing me thinks... maplin.co.uk sell flexible conduit in 13.8 or 17.2mm inner bore as well as heat-shrinkable sleeving/tubing in the cable and accessories section. [/ QUOTE ] That looks like the stuff... thanks! Link to comment Share on other sites More sharing options...
Sven Posted September 4, 2004 Report Share Posted September 4, 2004 Isn't there a small catch in the rings around the posts? I do know they sell head rests with LCD screens, both OE and aftermarket. Maybe that's a good solution? I suppose a wire will block the movement of the posts, or compromise the support. If you for some reason want to fit it yourself in the existing headrests, I'd perhaps opt for a curly 'phone cable', instead of trying to hide it. Link to comment Share on other sites More sharing options...
Riz Posted September 4, 2004 Report Share Posted September 4, 2004 Nope its called Helli-rap (not sure how its spelt) i used to use this stuff on Virgin Train insalltions. Riz p.s. think it was made by 3M Link to comment Share on other sites More sharing options...
russellfray Posted September 4, 2004 Author Report Share Posted September 4, 2004 [ QUOTE ] Isn't there a small catch in the rings around the posts? [/ QUOTE ] Not sure... will take a look shortly, thanks! [ QUOTE ] I do know they sell head rests with LCD screens, both OE and aftermarket. Maybe that's a good solution? [/ QUOTE ] Oooh do they - sounds perfect - I will have a hunt round! Link to comment Share on other sites More sharing options...
Jon Posted September 5, 2004 Report Share Posted September 5, 2004 The name of the stuff you are after is convoluted tubing, used to use loads of it on aircraft installations. As for suppliers try RS or Farnell Components, oh hang on, just found these guys: Convoluted Tuning Jon. Link to comment Share on other sites More sharing options...
Daz Posted September 5, 2004 Report Share Posted September 5, 2004 Something like this then? Which you can get from TLC Direct Link to comment Share on other sites More sharing options...
Paul Posted September 5, 2004 Report Share Posted September 5, 2004 its called all sort of things as mentioned. Kopex is another name, which is a trade name, but easily known at electrical wholesalers. Basically it is a form of flexible conduit. Some are more flexible and pliable than others. Link to comment Share on other sites More sharing options...
russellfray Posted September 5, 2004 Author Report Share Posted September 5, 2004 Thanks everyone Link to comment Share on other sites More sharing options...
Viraje Posted September 6, 2004 Report Share Posted September 6, 2004 [ QUOTE ] Nope its called Helli-rap (not sure how its spelt) i used to use this stuff on Virgin Train insalltions. [/ QUOTE ] They have lcd screens in the headrests on Virgin trains? They'll be kitting them out for fosgate power amps next. Link to comment Share on other sites More sharing options...
