Decked Posted January 27, 2005 Report Share Posted January 27, 2005 Anyone know what this is supposed to mean, "Alternator Workshop" It came up on the dash a few weeks ago and went off, then again the other day. Anyone had this before? I've had a look on the net and cant find anything, tempted on calling the garage, but it's going in for a range of jobs next week. Any ideas would be appreciated. Link to comment Share on other sites More sharing options...
s4dreamer Posted January 27, 2005 Report Share Posted January 27, 2005 It's happened to several of us in the past and generally it appears to happen when the car is starting to stall. Link to comment Share on other sites More sharing options...
Decked Posted January 27, 2005 Author Report Share Posted January 27, 2005 It's only ever happened as i've floored it out of my drive, slight wheel spin on the gravel then 10-15 seconds later when i'm up to about 60, thats when it comes up with the fault. Link to comment Share on other sites More sharing options...
Mollox Posted January 27, 2005 Report Share Posted January 27, 2005 10-15 seconds to 60 Link to comment Share on other sites More sharing options...
Decked Posted January 27, 2005 Author Report Share Posted January 27, 2005 I've laid off by this point!!!! Link to comment Share on other sites More sharing options...
Mollox Posted January 27, 2005 Report Share Posted January 27, 2005 I would too if it took that long to accelerate Link to comment Share on other sites More sharing options...
Zenyck100 Posted January 13, 2006 Report Share Posted January 13, 2006 Ive had "alternator workshop" flash up on my dash also. its happened twice this week. flashes up for a split second then off again. does anyone know why this is and shall i visit my dealer to sort it?? Link to comment Share on other sites More sharing options...
Decked Posted January 13, 2006 Author Report Share Posted January 13, 2006 I had the alternator replaced under warranty and everythings fine now Link to comment Share on other sites More sharing options...
Mook Posted January 13, 2006 Report Share Posted January 13, 2006 Get your main dealer or independent specialist to check it out - they can find out by plugging into the diagnostics system (main dealer) or VAG COM (independent). The ECU logs all errors, so they'll quickly be able to find out what the problem is for you. HTH Link to comment Share on other sites More sharing options...
Daemon Posted January 13, 2006 Report Share Posted January 13, 2006 *Usually* this message comes up when you bog the engine when launching and the revs drop well below idle speed and then recover. The alternator is unable to maintain full charging voltage so the ECU complains. Goes away immediately. If it happens anywhere above idle speed, then it may be a legitimate problem. ian Link to comment Share on other sites More sharing options...
