Auto boot opening retrofit?
Coda
Are you actually looking for the boot to fully open?
As you say, the boot will unlock and pop off the latch with a hold of the remote button. But you have to physically lift it to open it.
I'm not sure having it fully open on its own would be a good idea.
B6 saloon parts for the tailgate...
tailgate / boot lid / sedan
1 8E5827023D
tailgate / boot lid
(1) 8E5827023F
tailgate / boot lid / S4
(1) 8E5827023C
tailgate / boot lid / "J..","MEX".
(1) 8E5827023E
F 8E-2-148 701>>*8E-4-025 000*
(1) 8E5827023H
F 8E-4-025 001>>*
(1) 8E5827023G
tailgate / boot lid
F >> 8E-4-025 000* / "J..":S4
(1) 8E5827023M
tailgate / boot lid
F 8E-4-025 000>>* / "J..":S4
(2) 3B0827633C
base
adapt with workshop equipment
(2) 8E0827113
trim for licence plate / задн. / "J.."
8E0827113 1P9
black
3 8E5827249
stop buffer, adjustable / PR-5J0
(3) 8E5827249B
stop buffer, adjustable / PR-5J2
4 N 0162023
cup rivet / AK4X8X8,2
(5) 8E5827301C
bonnet hinge / left
5 8E5827302C
bonnet hinge / right
6 N 90520201
hexagon head bolt (combi) / M8X20-U-S1-L
7 N 90610701
hexagon nut, shouldered / M8
8 8E0827409
fitted bolt / M8X20
wiring conduit / left
see illustration: / 972-82
10 8D5827499
limit stop
11 8E5827373
limit stop
12 8E5827378
limit stop
13 8E5827505B
flap - lock / inner
14 8D5959489B
switch
15 N 90106302
hexagon nut, shouldered / M6
16 8E5827507
closure plate
17 N 90610701
18 8E5827520
cover cap
flap - lock
19 8E0953229
micro switch
20 8E5827531B
bonnet lock cable / задн.
F >> 8E-2-280 000*
20 8E5827531C
F 8E-2-280 001>>*
(21) 893827547
bush for connecting rod
21 8E5827547
F >> 8E-1-080 000
(21) 893839821
clip
F 8E-2-000 001>>
(21) 893837821A
clip
F 8E-2-000 001>>
22 4B5827552G
gas-filled strut / left/right
(22) 8E5827552A
gas-filled strut / left/right / sedan:
/ S4
(22) 8E5827552B
for vehicles with spoiler
23 443823397
clips
24 8E5962115
positioning motor
remote control
F >> 8E-4-270 000
(24) 8E5962115B
positioning motor
remote control
F 8E-4-270 001>>
26 N 90763001
torx socket head panel screw / ST4,8X28-C
27 8E5827521A
operating rod
F >> 8E-2-280 327 / задн.
(27) 8E5827521B
operating rod
F 8E-2-280 328>> / задн.
28 8E5827833
securing plate
29 N 10353801
torx socket fillister head panel screw (combi) / ST4,8X13-F-Z1
PLATTE AN KLAPPE
30 8E0827573
lock cylinder with keys and housing
* cannot be used to restore * * the one key locking * * system !! *
F >> 8E-2-290 000*
(30) 8E0827573A
F 8E-2-290 001>>*
(30) 107827573CD
lock cylinder without key
* to retain the one key * * system the key code * * number and/or chassis * * number must be quoted * * when ordering *
F >> 8E-2-290 000*
(30) 107827573CE
F 8E-2-290 001>>*
- 8E0827527
seal
lock cylinder
main key
see illustration: / 837-10
32 N 90533002
hexagon head bolt (combi) / M6X20
33 8E0827566
button for electrically operated flap - lock
F >> 8E-3-385 000
use if required: / 8E0 971 145
F 8E-3-385 001>>
position: / 35A
- 8E0971145
wiring harness for number plate light
34 N 90640201
fillister hd. bolt / M5X12-E
35 8E0827576
grip molding
8E0827576 3FZ
black
F >> 8E-3-385 000
35A 8E0827574C
grip molding
8E0827574C 3FZ
black
F 8E-3-385 001>>
36 8E0827594
gasket
37 8E0827657C
securing muff
F >> 8E-3-350 000 / left a. right
/ outer
(37) 8E0827657D
securing muff
F 8E-3-350 001>>* / left outer
(37) 8E0827657E
securing muff
F 8E-3-350 001>>* / right outer
38 8E0827657A
securing muff
F >> 8E-3-350 000* / left inner
(38) 8E0827657B
securing muff
F >> 8E-3-350 000* / right inner
(38) 8E0827657C
securing muff
F 8E-3-350 001>>* / left a. right
/ inner
(40) 8E0807430A
licence plate light / left
40 8E0807430B
licence plate light / right
41 8E5827705E
gasket for flap / задн.
42 8E5827976
grommet
43 8D5827713A
plug / 12X4MM
44 N 90648101
rivetted cap nut / M6/0,7-3B
45 G 052778A2
lock cylinder lubricant spray / 50ML
47 N 10406501
torx socket fillister hd. bolt / M6X12-H / "J.."
spoiler for tailgate / S4
see illustration: / 827-50
My Mercedes had this, and it was fantastic! Honestly it is the only thing I find missing from the A4 (so far)...
my mums lexus does it electronically - opens AND closes shut automatically - awesome and very posey.... well, we are in chavshire my darlings...!
I would have said something along the lines of upgraded struts would do this..... might go on an eBay / net trawl to see what i can find!!! My Avant struts are leaking anyway (common problem), so could be a good excuse!!! grin.gif
Iwas thinking about this also... Could be good; I borrowed an A6 sline saloon the other day and it was well useful when I was carring my laptop plus some other stuff but thought it could have a downside also as a couple of times I have pressed it by accident in the past and having the lid fly up would be annoying!. I assume this is a saloon mod only as the tailgate flying up would be dangerous/funny depending on your viewpoint and access to a paint shop!..
It was about £30 to spec it on my A4 so I assume the retrofit would be the same or cheaper....,
Anyone know specifically the part number out of that big list... I may go and ask for the 'muff' anyway!...
I'mthinking it would be a better mod on the saloon as you'd probably never risk the boot lid hitting anything.
If you did it on the Avant in a low/overhanging car park on in a garage, then the tailgate could hit something and be scratched.
picture the scene:
You are in the office and your car is outside in the carpark. Its pouring down with rain. You lean on the button on the fob in your pocket... boots pops open in the pouring rain!
Your in the office and your car is outside in the carpark. Its pouring down with rain. You lean on the button on the fob in your pocket... car unlocks, some git opens the door, and steals your stuff!.... how often has that happened, not! NONO3.GIF
picture the scene:
No picture needed... this has happened to me twice at home now. The first time I must have accidentally held down the unlock button in my pocket and the doors unlocked and the windows went down about 2 inches. Luckily the auto-door-locking-thingy locked the car doors again, but when I went out the car in the morning, I found both windows open and it had only gone and rained overnight! SAUER0421.GIF
If that wasn't bad enough, I somehow managed to do it again about 2 weeks later, but this time the windows went completely down and we had a heavy frost overnight. So, the next morning I spent 30 mins defrosting the inside of the car (the dash was white!) and mopping up water when the windscreen finally defrosted... Honestly, I did know whether to laugh or cry! yelrotflmao.gifSAUER0421.GIFyelrotflmao.gifSAUER0421.GIF
I now make a point of removing my keys from my pocket when getting home from work!
...that aside, I've got issues with my boot opening, so this would be nice mod! smashfreakB.gif
sorry, i've not been around to reply. i shall try to take a photo of the little spring damper later on. basically, it's just a little spring mechanism which upon unlocking the boot, causes the boot door to overcome the initial inertia, afterwhich, the pneumatics (is this the right term?) take over to fully raise the boot.
