TDiAvant Posted January 25, 2007 Report Share Posted January 25, 2007 Disconnect the Battery Remove the two plastic clips on either side of the steering wheel, this will expose the Torx Head screws that hold the airbag in place. Remove the Airbag and the disconnect the wiring harness from the steering wheel. Remove the Torx head screw holding the steering wheel in place. Image Remove the lower foot well trim and disconnect the diagnostic port and the light connector. Using a long reach torx screw driver remove the 2 screws at the front of the lower cowling section and also remove the cap head screw from the middle of the lower cowling. Remove the slip ring, which is held in with 3 clips 1 at either side and 1 at the bottom, then disconnect the wiring connector Unscrew the wiper arm control unit and the indicator control unit, each one is held in with 2 torx screws. And remove the cap head screw which is located just behind the V shaped piece of plastic. Remove the wipe control arm and disconnect the wiring going into the back of the SCSM on the left hand side. Unplug the indicator arm and the SCSM can be removed. Push the new SCSM module in place and connect the wiper arm, indicator arm and the cruise arm. Remember each arm is held down with two torx screws. Reconnect the wiring harness to the new SCSM module, and Screw the cap head screw back in place. Reconnect the slip ring and connect the wiring harness. Put the cowling back in place remembering to use the new lower cowling section. Screw back together using the 2 torx screws and the cap head screw. Put the lower foot well trim back in place, remembering to connect the diagnostic port and the light. The steering wheel back onto the car and try and set it at a level position, fix the wheel in place with the torx screw. Reconnect the airbag wiring harness and refit the airbag. Screw the airbag back in place and put back the small plastic clips. Reconnect the battery and connect the vag-com to the system. First of all if you fitted a new SCSM like I did you would need to code the SCSM with the correct coding Open VAG-COM Press Select [16 Steering wheel] Select Coding. Enter the correct coding for your car. Select Do It! Select fault codes Clear fault codes. Confirm non re-appear Close controller The next step is to complete “Steering Angle Sensor (G85) Calibration” I will not write this up as it can be found on the ross-tech web site. http://wiki.ross-tech.com/index.php/...28Bosch_8.0%29 The final step is the coding of the engine for cruise control. Engine 01 Coding-II 11 Enter 11463 Select Do It! I would then do a complete scan of the car and clear any fault codes as the battery has been disconnected. Link to comment Share on other sites More sharing options...
Sparky Posted January 25, 2007 Report Share Posted January 25, 2007 Nice installation Link to comment Share on other sites More sharing options...
Sponge Posted January 25, 2007 Report Share Posted January 25, 2007 Excellent job, thanks. I think I'll bookmark this page for future reference. PS Can I ask where you got the parts from? Link to comment Share on other sites More sharing options...
TDiAvant Posted January 25, 2007 Author Report Share Posted January 25, 2007 vagparts Link to comment Share on other sites More sharing options...
Davef Posted January 27, 2007 Report Share Posted January 27, 2007 Lee, Do you have the part number for the replacement lower steering cowl (assuming that your car colour is soul)? Dave Link to comment Share on other sites More sharing options...
TDiAvant Posted January 27, 2007 Author Report Share Posted January 27, 2007 8E0 953 512 P 6PS is the code for soul (black) Link to comment Share on other sites More sharing options...
vanduara37 Posted January 28, 2007 Report Share Posted January 28, 2007 Is it possible to tell how much this costs as i see it on www.Audi-Accessories.co.uk for £147 (without mfsw)which includes everything even a new lower cowl,would like to know if this is a good price. john Link to comment Share on other sites More sharing options...
TDiAvant Posted January 28, 2007 Author Report Share Posted January 28, 2007 It sounds ok. I got all my gear from vagparts but I placed a 2k order so I got a good discount. Link to comment Share on other sites More sharing options...
gizze Posted January 28, 2007 Report Share Posted January 28, 2007 There is a guy selling the kit on ebay for £80 for cars with multifunction wheel and £145 for cars without. Link to comment Share on other sites More sharing options...
nordberg Posted January 29, 2007 Report Share Posted January 29, 2007 [ QUOTE ] There is a guy selling the kit on ebay for £80 for cars with multifunction wheel and £145 for cars without. [/ QUOTE ] You got a URL? Can't find it..... Link to comment Share on other sites More sharing options...
techieboy Posted January 29, 2007 Report Share Posted January 29, 2007 This might be the guy, I was going to use him before Xmas as it includes fitting. Just never got around to fixing up an install and this thread has now reminded me..... eBay Shop Link to comment Share on other sites More sharing options...
TDiAvant Posted January 29, 2007 Author Report Share Posted January 29, 2007 How much no wonder it's a free install Link to comment Share on other sites More sharing options...
techieboy Posted January 29, 2007 Report Share Posted January 29, 2007 Lee, if you're ever passing through Bedfordshire, feel free to stop by mine for a beer and retrofit session I know I can get the required bits from Bedford Audi for £65 but I haven't got VAG-COM or the necessary bottle to start dismantling the car to fit it. Last time I removed a steering wheel was on my first car 20 years ago and the bloody thing was never straight again. Link to comment Share on other sites More sharing options...
TDiAvant Posted January 29, 2007 Author Report Share Posted January 29, 2007 I don't travel to that area very much, so I think Shark_90 would be your best bet Link to comment Share on other sites More sharing options...
gizze Posted January 29, 2007 Report Share Posted January 29, 2007 http://cgi.ebay.co.uk/Audi-A4-Cruise-Con...VQQcmdZViewItem Here is Bedford Audis ebay shop, they are doing the kit for £40. Link to comment Share on other sites More sharing options...
TDiAvant Posted January 29, 2007 Author Report Share Posted January 29, 2007 But add £25 for the lower trim Link to comment Share on other sites More sharing options...
vanduara37 Posted January 29, 2007 Report Share Posted January 29, 2007 I haven,t seen the full kit but was wondering if the original cowl could be modified to accomodate the new cruise stalk Link to comment Share on other sites More sharing options...
gizze Posted January 29, 2007 Report Share Posted January 29, 2007 Yeah I am sure it could. It is just a deeper cut out below the indicator stalk I think. Link to comment Share on other sites More sharing options...
TDiAvant Posted January 29, 2007 Author Report Share Posted January 29, 2007 yes it could but unless you are very good with a dremel, I would just but the lower cowling Link to comment Share on other sites More sharing options...
the911sc Posted January 31, 2007 Report Share Posted January 31, 2007 I got all my parts from the main dealers for 50 quid (I have a mfsw so didnt need the steering wheel ecu).. They actually fitted it for me for free too ! (well, I have bought quite a few cars from them!) Link to comment Share on other sites More sharing options...
tsmott Posted August 9, 2010 Report Share Posted August 9, 2010 Hi there, Any change of getting the pistures back? I can't figure out how to get the slip ring out without breaking anything. Thanks. Link to comment Share on other sites More sharing options...
S4_marv Posted August 11, 2010 Report Share Posted August 11, 2010 I've put a guide on google docs here, which has some pictures, but they probably don't help with the slip ring specifically, but the instructions I wrote at the time were: Remove the slip ring, which is held in with 3 clips; 1 at either side and 1 at the bottom. Then disconnect the wiring connector, which is the yellow connector at the top right, to the rear.I seem to remember that one or more of these clips, or the connector was pretty tight. Link to comment Share on other sites More sharing options...
tsmott Posted August 29, 2010 Report Share Posted August 29, 2010 Can we get the photos back here please!? Link to comment Share on other sites More sharing options...
