eldiablorubino Posted January 25, 2007 Report Share Posted January 25, 2007 just been out to my car and discovered a 20p coin glued to the roof of my car... does anyone have any suggestions to try and remove it? it appears to be well stuck with superglue or similar. can't get anything underneath the edges at all. (FYI - the car was polished a couple of weeks ago with Klasse AIO if that makes any difference) TOTAL S - Link to comment Share on other sites More sharing options...
SamD Posted January 25, 2007 Report Share Posted January 25, 2007 That is the most bizarre act of vandalism I have ever heard of I am sure someone will have an idea of how to get it off without too much damage s Link to comment Share on other sites More sharing options...
Jez Posted January 25, 2007 Report Share Posted January 25, 2007 Unbelivable ! you could try the debadge method ? Use a hair dryer to heat it up and try and slide some dental floss or fishing wire underneath ? good luck. Link to comment Share on other sites More sharing options...
AZURES3 Posted January 25, 2007 Report Share Posted January 25, 2007 I would try a garage jet wash first the warm water, soap and pressure may just lift it off. AZ Link to comment Share on other sites More sharing options...
eldiablorubino Posted January 25, 2007 Author Report Share Posted January 25, 2007 thanks for the suggestions so far. i have tried hot water and pouring lighter fluid around the edges to see if i can break down the glue seal around the edges and get anything underneath... no joy so far... GRRRRR! Link to comment Share on other sites More sharing options...
Ska Posted January 25, 2007 Report Share Posted January 25, 2007 acetone (nail polish remover), hot water, or Super Glue Remover in moderation if all else fails but mask off surroundings what ever you do, what w4nker goes out of his/her way to do something like that Link to comment Share on other sites More sharing options...
RReflections Posted January 25, 2007 Report Share Posted January 25, 2007 Most modern super glues are water soluble, however its not a 5 minute soak and off it'll come Unfortunately I think no matter what you do, you will find some paint damage at the end of it, so I would suggest masking round the coin, leaving a couple of mm gap, then use some of the correct remover in small quantities and start working round it slowly, wiping up excess after a few seconds. As and when the coin is off, don't be tempted to scrape any glue remnants off, rather again use remover are cloth to lightly wipe away. Finally if you are lucky there will be minimal marrings that should be able to be polished out or at least reduced. On the idiots who thought this would be funny, I think a squirt of super glue into their bell end would be a nice experience for them Link to comment Share on other sites More sharing options...
tonygould Posted January 25, 2007 Report Share Posted January 25, 2007 [ QUOTE ] what w4nker goes out of his/her way to do something like that [/ QUOTE ] a jealous w4anker. hope there is no lasting damage to your car mate. Link to comment Share on other sites More sharing options...
ahaydock Posted January 25, 2007 Report Share Posted January 25, 2007 [ QUOTE ] On the idiots who thought this would be funny, I think a squirt of super glue into their bell end would be a nice experience for them [/ QUOTE ]Agreed - why!? Hope it comes off OK. Link to comment Share on other sites More sharing options...
NeilScarrott Posted January 25, 2007 Report Share Posted January 25, 2007 Don't use acetone! It could well damage the paint. Best to try some dedicating glue remover, something like Autoglym Tar and Glue remover. Soap some in a tissue and leave on the effected area. I think you'll have most success with a source of heat, a heat gun or hair dryer, although do not get the paint very hot, be very careful. Link to comment Share on other sites More sharing options...
eldiablorubino Posted January 25, 2007 Author Report Share Posted January 25, 2007 just been outside... armed with: - jug of boiling water - torch! after very carefully and slowly pouring boiling water over the coin for about a minute, a quick shove with my fingers and... BINGO! it came off! went back outside... armed with: - thumbnail - microfibre cloth - sonus microfibre pad - Klasse AIO - torch! managed to scrape the glue residue off with my thumbnail and then gave it a quick polish to protect the paint again. initial results look pretty good, there is some marking of the paintwork, need to see it in daylight now... (note: the outside temp is about -1ºC at the moment so the drastic change in temp with the boiling water may have helped to release it) thanks for all your advice and support. still can't believe the jealous F*CK*RS. Thing is around the village where I live there are loads of really nice cars... (Audi RS4s, RS6s, A8s, a couple of GTIs, Range Rovers, RR Sports) it's not like it is parked in the middle of a council estate in an inner city... Link to comment Share on other sites More sharing options...
bazza_g Posted January 25, 2007 Report Share Posted January 25, 2007 Glad you managed to get it and the rest of the residue off what kind of fecker does that to someones car? drives me nuts Link to comment Share on other sites More sharing options...
kite Posted January 25, 2007 Report Share Posted January 25, 2007 Barstewards,hope the paints OK Link to comment Share on other sites More sharing options...
Vagabond Posted January 25, 2007 Report Share Posted January 25, 2007 Sounds like a schoolboy prank. Keep your eye open in case they try it again. A good boot up the arse is whats called for. Thankfully your car is ok! Link to comment Share on other sites More sharing options...
Hudson Posted January 25, 2007 Report Share Posted January 25, 2007 wow, there are some seriously Fooked up people out there in the ''nice areas'', if that happens in a village i wonder what really happens on the council 'sink' estates, must be like a bad day in Faluga. Link to comment Share on other sites More sharing options...
Calm Chris Posted January 25, 2007 Report Share Posted January 25, 2007 Tight b4stards, could have used a £1 or £2 coin The hot water trick would have been what I would have suggested, then surgical spirit and then a sharpe firm tap with a spoon Hope the paint is okay. Link to comment Share on other sites More sharing options...
bpsmith Posted January 26, 2007 Report Share Posted January 26, 2007 More than likely that the kids did this rather than some jealous adult? In hindsight, it is better that they did that than the usual key or coin down the side in wavy lines!?! Dont get me wrong, I would have gone ballistic at what has happened too mind you!!! Link to comment Share on other sites More sharing options...
Richy Posted January 26, 2007 Report Share Posted January 26, 2007 You should have tried to get a finger print of the surface of the coin, C.S.I. style Link to comment Share on other sites More sharing options...
Speedywheels Posted January 26, 2007 Report Share Posted January 26, 2007 Just kick the nearest kid and tell him to pass it on - the culprit will eventually get his 'reward' Link to comment Share on other sites More sharing options...
davidhodgkinson Posted January 26, 2007 Report Share Posted January 26, 2007 Bad news - Why do they do this? I'm glad I lock my car in the garage overnight. Link to comment Share on other sites More sharing options...
lesK Posted January 28, 2007 Report Share Posted January 28, 2007 you could try building a reservoir around the coin with something like plastecine then use hot water just keep topping it up (don't use boiling you may wreck the paint!) I'm not sure if this will work but hot water is supposed to be able to help seperate superglued parts. Hope you get it off, and if you catch them, glue their eyelids shut! I'm pretty sure you can buy a superglue remover from someone like RS Components but not sure what it'll do to paint Link to comment Share on other sites More sharing options...
