Serious Home Incident - Help Needed (with Pics)
UBM
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Straight forward fixing and design error.
I would have expected toggle bolts or stud fixing via epoxy or stud fixing and plate inside the wall.
The worse thing is that the fixings may well have held, if concrete tiles hadn't been used as the porch roofing material. I forget how heavy they are, but I'd imagine that they would add at least a hundred weight to the porch mass.
It would be interesting to ask if the porch contractor was responsible for the roof, or was it a job of two halves?
Expect full reinstatement of porch, roofing and lead work.
Expect a new front door and replacement of any damage to frame and fabric.
Expect the garden and pathway to be repaired.
Expect £500 as a gift
I would suggest that due to previous poor workmanship that you insist on a written guarantee for a fresh 10 year period.
Just thinking about the publicity angle. You could end up shooting yourself in the foot.
If they became known as the houses wher the porches fall off, I would imagine the value may drop quite a bit and surveyors would be super stringent doing surveys.
Not good for you.
Its unfortunately fairly typical of modern housebuilders and thier standards. In reality that would probably have stood up for 10 years, and then you'd have had no arguements, just the builder trying to be cheap and cut corners frown.gif
As MRm3 said - speak to the local, they'll be happy to help speedy resolution.
That is terrible! Real crap build. My shelves in the my garage are held up with more rawlplugs than that!
I certainly hope you get it sorted PROPERLY!
Where I am, there are a few PS homes, and the porch's look disctinctly askew. However, they seem to be a bit 'meatier'.
Glad my place has a simple plastic lip thingy.
Why even involve the press ?
Ok, the accident is being resolved (these things take time and it WILL take time)a porch is a porch and in most cases is only decorative, as no structural damage is involved and no breach of security and thankfully no one was hurt only shaken.
It seems that as soon as anything happens nowadays the first thing anyone does is call the press, surely to progress the correct channels is the right way to go and let the process begin.
Your household insurers will progress this and will act on any suggestions you have, but to start off by belly-aching to the press about WHAT MAY have happened and too p1ss off all those involved in resolving the problem is very counter-productive.
What the NHBC will pay for.
A The full Cost, if it is more than £1000
Indexed, of putting right any actual
physical Damage caused by a Defect in
any of the following parts of the house,
bungalow, maisonette or flat and its
garage or other permanent outbuilding,
or its Common Parts:
; Foundations
; Load-bearing walls
; Non load-bearing partition walls
; Wet-applied wall plaster
; External render and external vertical
tile hanging
; Load-bearing parts of the roof
; Tile and slate coverings to pitched roofs
; Ceilings
; Load-bearing parts of the floors
; Staircases and internal floor decking
and screeds where these fail to
support normal loads
; Retaining walls necessary for the
structural stability of the house,
bungalow, flat or maisonette, its garage
; Double or triple glazing panes to
external windows and doors
; Below-ground drainage for which you
are responsible
B The Cost of putting right any Defect in
a flue or chimney which causes a
present or imminent danger to the
physical health and safety of anyone
normally living in the Home.
C Any reasonable costs you incur by
prior agreement with us for removal,
storage and appropriate alternative
accommodation if it is necessary for you
or anyone normally living in the Home to
move out so that work can be done.
What it will not pay for
Any claim under A where the Cost of
repair is £1000 or less, Indexed.
Damage caused by shrinkage, thermal
movement or movement between
different types of materials.
Damage which is purely cosmetic, such
as minor cracking, spalling or mortar
erosion to brickwork, which does not
impair the structural stability or weather
tightness of the Home or which only
affects decorations.
Any Defect in existing double or triple
glazing panes in converted properties
unless they were newly installed at the
time of conversion.
Damage resulting from the entry of
water to an underground car park.
Anything which was or could have been
reported to the Builder under Section 2.
For these claims, please see Section 2 of
the policy on page 8.
Any Defect in a ceiling which is not in
an enclosed part of the Home, eg.
balcony ceilings.
The above is just a sample from the buildmark booklet. If you want a full copy of the NHBC buildmark booklet, let me know and I will e-mail it to you. If you let me know what builder it is I will see what I have warranty wise on them as I deal with a lot of the major house builders. 169144-ok.gif Good luck.
Thanks - I pulled out our NHBC booklet from the cupboard.
THe building company are currently bending over backwards to help.
And FatCat, I know it is only a porch, but I could quite easily be sat here now wifeless and childless..... frown.gif
Or they fatherless.
On the odds, falling down on someones head was a possibility rather than a probability.
A bit like nearly having a car accident and having one.
You will get something for anguish, settle on asking for a nice holiday, they might just take that.
Otherwise it lose all good will, drag it to court at your cost (no legal fees for the working classes frown.gif), wait 3 years and get £XYZ- but not much since they have made full repair.
Not a nice thing to happen and I can assure you, in life things do happen that upset due to people not doing things the right way frown.gif.
You were unfortunate (or very fortunate if your a positive thinker).
Do make sure that as part of the overall package that stress testing is carried out on every other property, including back one's should you have such.
UBM......only just spotted this mate and FECK ME!!!
This reminds me of when I was living in an area of Poplar in 91 or so. We had bought a house that was intended to be used for EPDs, but it got palmed off for sale instead. So just me and the wife, small place, 1 nipper etc.
House brand new......was in for 6 months, then one day came home from work, opened the door and there was a hell of a lot of dust in the air. Like plasterboard type dust. In fact it was so thick I could taste it before I could take me coat off.
Walked through living room, beige carpets were almost white in dust.....SH!T......walked a bit further in to dining room, more dust. Went into kitchen and found everything apart from the bathroom excluding the bath in my kitchen. Lots of dust, water and a right feck off mess in a house of about 6 months old.
The house was built by LAING. So got onto them, and within an hour a bod came out who inspected the scene, made a few phone calls and had us placed in a hotel until the repairs were made. Two weeks later, we got the keys back, place was immaculate. Only hassle was waiting for their insurance co to cough up for replacement to damaged furniture and carpets. Only had to wait 3 days though for carpets, but unfortunately about 2/3 weeks for furniture.
We stayed there for another 8 years before moving and only had to call on NHBC once and that was for a replacement front door canopy that had detached from one of its fixings. It was a pitch design, but nothing as nice as what you have on yours. All replaced, stress tested etc. We never coughed up a penny.
As I said before - I really wouldn't call the press or get any publicity if at all possible.
.......Unless nobody on the estate ever wants to sell their house in the future - or own a house that had devalued £10k overnight - cause the public perception is that they fall down.
UBM - you will have more chance of getting food poisioning and dieing as a result
You will have more chance of getting run over and dieing
You will have more chance of drving and getting killed
You will have more chance of dieing in a plane crash
Yes, it's not nice to think what may have happened, but do you think the same thing when you take your loved ones out every time in your car or even every time when you cross the road.
At the end of the day, everyone is ok and the thing is being settled and resolved.
Move on.
