Mook Posted October 18, 2007 Report Share Posted October 18, 2007 Having found the stock brakes on the S4 to be not really up to the job on the track, where do I get a B7 RS4 upgrade now that audi-accessories.co.uk is offline until the end of the year? Quote Link to comment Share on other sites More sharing options...
P_G Posted October 18, 2007 Report Share Posted October 18, 2007 VAG-parts sell all the necessary bit, but ain't that cheap. AMD / BBT and APS still sell the conversions too. The cheaper alternative which may improve the brake performance is having braided lines put on and heavier brake fluid? Quote Link to comment Share on other sites More sharing options...
techieboy Posted October 18, 2007 Report Share Posted October 18, 2007 [ QUOTE ] VAG-parts sell all the necessary bit, but ain't that cheap. AMD / BBT and APS still sell the conversions too. The cheaper alternative which may improve the brake performance is having braided lines put on and heavier brake fluid? [/ QUOTE ] As P_G said. might be worth doing that first, anyway. And then maybe getting some harder compound pads as well - Pagid RS14's (or even harder) if they make them for the S4. The brakes are a bit of a weakpoint on the VX so I run Mintex 1144 pads for road use and swap over to RS14's for the track. Reckon I've at least doubled the amount of laps I can do before fade sets in and the feel is sooo much better. I just got decent quality DOT 5.1 brake fluid and didn't bother with any trick/expensive race orientated stuff that might need replacing every other month. Quote Link to comment Share on other sites More sharing options...
Mook Posted October 18, 2007 Author Report Share Posted October 18, 2007 It's the pads that fade - the fluid doesn't have enough time to get hot - the pedal doesn't go long at all, so adding braided lines and changing the fluid won't make any difference. From previous experience of using after-market pads on the OEM disks, you don't get much of an improvement. For me, the only option is bigger disks and calipers. The RS4 upgrade was a favourite of several people at the Audi Driver event at Combe - I chatted with Phil Millington from Milltek and he used to run the B7 RS4 upgrade on his S4 around Combe and recommended it. Not sure if £3.3K+ from AMD is much of a bargain! Quote Link to comment Share on other sites More sharing options...
chasdrury Posted October 18, 2007 Report Share Posted October 18, 2007 Are you still trying to persuade people it's a S4, Mook? Everyone on Scumball knows it's a 1.9TDi! Quote Link to comment Share on other sites More sharing options...
Mook Posted October 18, 2007 Author Report Share Posted October 18, 2007 Shhh! Before everyone finds out Duisberg's ad stuck on my window the first morning of Scumball... Quote Link to comment Share on other sites More sharing options...
J_C Posted October 18, 2007 Report Share Posted October 18, 2007 PMSL Quote Link to comment Share on other sites More sharing options...
EssFour Posted October 18, 2007 Report Share Posted October 18, 2007 One of the members over on RS246 fitted RS6 calipers with Phaeton discs RS246 Quote Link to comment Share on other sites More sharing options...
Matt R Posted October 18, 2007 Report Share Posted October 18, 2007 I may be able to help here! Quote Link to comment Share on other sites More sharing options...
PetrolDave Posted October 18, 2007 Report Share Posted October 18, 2007 Don't you need at least 18" wheels with RS4 front brakes? The RS4 is only available with 18" or 19" wheels, and people who have tried to fit a 17" space saver on the front wheels have said it won't go over the brakes. Quote Link to comment Share on other sites More sharing options...
P_G Posted October 18, 2007 Report Share Posted October 18, 2007 Sorry Mook, I didn't realise AMD had put their price up! £3.3K is extortionate! APS would do it for approx £1800 IIRC. However you would need H&R spacers so your Avus wheels fit over the new calipers. Unless you are after a 19" aftermarket quality set of wheels (only kidding!) I have heard of people using the B7 RS4 disk and the RS6 caliper which is supposedly narrower in dimension / construction, but spacers are still needed. It does solve the front brake problem and I had it on my old S4, much better stopping power. Unfortunately on the B6 you can only do the front upgrade, on a B7 S4 you can do front and rear. Otherwise the cheapest alternative I researched was a Movit kit at £4K front and back and a v.good kit. Pricey though. Quote Link to comment Share on other sites More sharing options...
Mook Posted October 19, 2007 Author Report Share Posted October 19, 2007 [ QUOTE ] Don't you need at least 18" wheels with RS4 front brakes? [/ QUOTE ] Shouldn't be a problem as the S4 has 18" wheels Quote Link to comment Share on other sites More sharing options...
Mook Posted October 19, 2007 Author Report Share Posted October 19, 2007 [ QUOTE ] However you would need H&R spacers so your Avus wheels fit over the new calipers. Unless you are after a 19" aftermarket quality set of wheels (only kidding!) [/ QUOTE ] Any idea what size spacers? Mmmmm. Nice aftermarket wheels. You mean like 19" B7 RS4 replicas...? Quote Link to comment Share on other sites More sharing options...
P_G Posted October 19, 2007 Report Share Posted October 19, 2007 was thinking more along the lines of 19" Sportec Monos. As for spacers I used the RS4 calipers and needed 10mm (per spacer so 20mm in total peraxle) H&R hubcentric spacers which I got from the TT Shop for approx £170-180 for both axles including 20 new TUV approved H&R longer bolts. IIRC those using the RS6 calipers only needed 5mm hubcentrics. So you get better stopping and better handling with an increased track. Best ask Sam about the RS6 calipers IIRC this is what he got from APS? Quote Link to comment Share on other sites More sharing options...
Mook Posted October 19, 2007 Author Report Share Posted October 19, 2007 Quote Link to comment Share on other sites More sharing options...
P_G Posted October 19, 2007 Report Share Posted October 19, 2007 Quote Link to comment Share on other sites More sharing options...
Avus_Bub Posted October 19, 2007 Report Share Posted October 19, 2007 Mook,if you go for spacers get MTM ones. The H&R's are a made about 5mm too small for the mounting face of the hub. The MTM's are full size I know they are both TUV approved but I think the MTM ones offer a little more peace of mind. HTH BUB Quote Link to comment Share on other sites More sharing options...
Mook Posted October 20, 2007 Author Report Share Posted October 20, 2007 Cheers, Bub That can't be a pic of your car - it's too dirty Quote Link to comment Share on other sites More sharing options...
Avus_Bub Posted October 20, 2007 Report Share Posted October 20, 2007 You've a keen eye Mook I don't know how people can keep their cars in such a two an' eight........... P.S. 10mm out back and 8mm up front is just about perfect Quote Link to comment Share on other sites More sharing options...
