Mike_cabrio Posted October 12, 2008 Report Share Posted October 12, 2008 Can anyone confirm what wiring I will need to connect heated seats in my car. I have the climate control with heated seat switches ? thanks Mike Link to comment Share on other sites More sharing options...
UBM Posted October 13, 2008 Report Share Posted October 13, 2008 If you have the switches, they should work? Link to comment Share on other sites More sharing options...
Cupramax Posted October 14, 2008 Report Share Posted October 14, 2008 Are you sure UBM, surely they dont fit the heating elements to standard cars...? Link to comment Share on other sites More sharing options...
PeterS Posted October 14, 2008 Report Share Posted October 14, 2008 I'm guessing that Mike has bought a replacement CC panel with the heated seat switches, and that UBM interpreted it as his car already had the switches fitted :confused: At a guess you'd require heating elements, loom and relays (??) to make a retro-fit work. However, please don't take my word for it - I have to get the garage to change a bulb Peter Link to comment Share on other sites More sharing options...
cosmicblue Posted October 14, 2008 Report Share Posted October 14, 2008 Back in the days when I had my Saabs addiction (a very expensive condition due to rubbish residuals) it was well known that all the seats had the heater pads in as standard. During production the connectors under the seats were chopped off if heated seats were not specified. Given that the pads probably cost peanuts in production terms it may be possible that seats have the pads already............. Link to comment Share on other sites More sharing options...
PetrolDave Posted October 15, 2008 Report Share Posted October 15, 2008 Given that the pads probably cost peanuts in production terms it may be possible that seats have the pads already............. Previous people who have looked into this have always found that the heating elements are NOT fitted by Audi unless you order heated seats - maybe Audi have a better logistics system than Saab? Link to comment Share on other sites More sharing options...
Chav Posted October 15, 2008 Report Share Posted October 15, 2008 the heated pads arent standard fit. you need lower/upper heating elements for each seat, wiring harness and switches. Cost is about £350 for adding them to the rear. (I enquired on my old cab) You will need to reupholster afterwards. As you have the switches, you just need heating elements and wires - literally. this is from an email from vagparts in 2004. I'd expect the prices to still be similar.... Heated rear seats? Yup! Sure can. In the crudest sense, the base parts are: Each seat base heater mat £107.95+vat each Each seat backrest heater mat £67.47+vat Heated seat switch (goes in the rear of the centre console under the ashtray), they are £27.83+vat each. Wiring for the seats, that should be simple enough to make your own loom , basic stuff that. Link to comment Share on other sites More sharing options...
Mike_cabrio Posted October 15, 2008 Author Report Share Posted October 15, 2008 (edited) Thanks for everyones help. I am retrofitting these I have the seats with the green plugs and so I presume are heated, I also have the climate control with heated switches. Just need to know what I need to connect heated seats to climate control and from climate control to fuse board ? reason I ask is I believe some people have retrofitted these ?? Edited October 15, 2008 by Mike_cabrio Link to comment Share on other sites More sharing options...
techieboy Posted October 15, 2008 Report Share Posted October 15, 2008 Just make sure those green plugs aren't for the integrated airbags or seatbelt pretensioners otherwise it could be "interesting" when you first rotate the switch. Link to comment Share on other sites More sharing options...
PetrolDave Posted October 17, 2008 Report Share Posted October 17, 2008 Airbags and pre-tensioners "usually" have yellow coloured plugs. Link to comment Share on other sites More sharing options...
Mike_cabrio Posted October 18, 2008 Author Report Share Posted October 18, 2008 the seats were delivered today but they gave me the wrong climate control it was from an 06 A3 , does anyone know if this will work in an 2004 A4 ?. Also i have been looking on ebay for climate controls with heated seat switches an there is an 04 A6 one which looks identical to the A4 any idea if this will work ? Link to comment Share on other sites More sharing options...
Davef Posted October 20, 2008 Report Share Posted October 20, 2008 Hi Mike, I did this retrofit last year in an A4 saloon and several others have also completed it. The climate control you have (from an A3) will not fit - you will need one from an A4 saloon or cabrio from at least the same model year that your car is. In relation to the wiring you will need access to the factory wiring diagrams to make up your own loom or you can buy a wiring loom from kufatec which is what I did. Its pretty simple to wire up as all the terminals are on the loom. Running the wires is time consuming to say the least. Regards Dave Link to comment Share on other sites More sharing options...
DanG Posted October 21, 2008 Report Share Posted October 21, 2008 slightly off topic, but have you retro fitted heated mirrors? i have just done mine but they wont work when the rear scren heater is pressed.... does it have to be cold before they work or do i need VAGCOM?? cheers Link to comment Share on other sites More sharing options...
chasdrury Posted October 22, 2008 Report Share Posted October 22, 2008 Under 12 degrees IIRC - if the outside temp is above they don't come on... Link to comment Share on other sites More sharing options...
Mike_cabrio Posted October 23, 2008 Author Report Share Posted October 23, 2008 Hi, Davef thanks for your help on this. I think I will go with the loom from Kufatec (do I need for heated seats and electric seats (or just heated seats as already had electric seats ?). Also what are the best manuals for the audi a4 cab? Going to do it in a week or so. So will let you know if I run into any problems thanks Mike Link to comment Share on other sites More sharing options...
Davef Posted October 23, 2008 Report Share Posted October 23, 2008 Mike, you will not need the loom for electric seats unless your new seats are electric and your old ones aren't. Most seats have electric lumbar support in any case so there is a power supply to the seats. From memory there are 4 plugs: yellow seat airbag, brown power, green seat heating and black which is for the seatbelt warning. The kufatec loom (from KUFATEC GmbH) has all the wiring you need and also includes basic instructions. I needed a terminal release tool as I recall to release a connector from the fuseboard. I used elsawin which is very very useful for wiring diagrams and dis-assembly instros (try fleabay) Pm me if you want to talk it through. Dave Link to comment Share on other sites More sharing options...
Davef Posted October 23, 2008 Report Share Posted October 23, 2008 Mike, Forgot but you will probably need VCDS (vagcom) to clear any fault codes from the climate control (and also adapt it to your car if its from a different model) Where in the Uk are you? Dave Link to comment Share on other sites More sharing options...
Mike_cabrio Posted October 24, 2008 Author Report Share Posted October 24, 2008 Dave, Hi, I ordered the lead from kufatec. Are you saying that because the climate control is from a 2006 audi a4 cabriolet it wont work in my car ?. I am in merseyside thanks Mike Link to comment Share on other sites More sharing options...
Davef Posted October 25, 2008 Report Share Posted October 25, 2008 Mike, Should work fine. Dave Link to comment Share on other sites More sharing options...
Mike_cabrio Posted October 30, 2008 Author Report Share Posted October 30, 2008 Ok wiring for heated seats arrived this morning but the instructions are in German so anyone who has used the Kufatec loom could you tell which wires go where and do I need to disconnect passenger airbag etc ? thanks Link to comment Share on other sites More sharing options...
cocain Posted October 31, 2008 Report Share Posted October 31, 2008 Sorry i ain't been on for a while. i have them somewhere i will post Link to comment Share on other sites More sharing options...
cocain Posted October 31, 2008 Report Share Posted October 31, 2008 Ok here are the instructions but mine was for heated electric loom hope it helps Dear Customer, this are the instructions. Both connectors are available behind your climate control, you don't have to buy any of the connectors since they already exists behind your climate control. Please contact a professional for installation ------------------- Seatheating Connector C,F are behind the climate control and already exist in the car’s loom. F has 6 pins Grey-wire with yellow tull goes into Connector F 1 Grey-wire without tull goes into Connector F2 Red-White goes into F3 Violet goes to C5 Yellow goes to C6 Red/white will be connected to Terminal 30 (permanent plus) and the other end will be inserted into the fuse box of the car (Fuse number 44). The other red/white connector of the wiring will be inserted into the other free slot of the fuse box. Brown will be connected to a ground point of the car close to the A-Pillar Link to comment Share on other sites More sharing options...
PetrolDave Posted November 1, 2008 Report Share Posted November 1, 2008 There might be a translation of the instructions you can download from the Kufatec website, or you could use the Google translator. Why do you ask specifically about the passenger airbag? Both driver and passenger seat have the same side airbag arrangement. The passenger airbag is in the dash and the driver airbag in the steering wheel. Link to comment Share on other sites More sharing options...
Mike_cabrio Posted November 2, 2008 Author Report Share Posted November 2, 2008 ok attempted this today but ran into some problems with the loom,what is the best wiring route for the heated seat plugs do i need to take out the centre console and how do you get the plugs into the floor with the other plugs (i.e. red, yellow plugs etc ?) how long has it taken for people who have done this to put the wiring in from start to finish ? thanks Link to comment Share on other sites More sharing options...
Mike_cabrio Posted November 6, 2008 Author Report Share Posted November 6, 2008 Hi, I thought a few people had fitted the heated seats wiring ? Link to comment Share on other sites More sharing options...
