Korkster Posted March 27, 2006 Report Share Posted March 27, 2006 Should they be used or are they potentially going to cause damage to paintwork especially if a piece of grit etc gets caught whilst using! Any one out there use them? Any differences between the Halfrauds or AG Blades etc (apart from price)? Link to comment Share on other sites More sharing options...
mb Posted March 27, 2006 Report Share Posted March 27, 2006 Hi, I have the Aquaglym (sp?) blade - works really well, I rinse it before use and check all OK then use it to skim off the bulk of the water (one or two stokes on each panel) then use a microfibre drying towel to dry properly. Link to comment Share on other sites More sharing options...
Sponge Posted March 27, 2006 Report Share Posted March 27, 2006 I bought one but have been too scared to use it. I don't think it's worth the risk of catching a stray piece of dust or sand. To be honest, I find the correct use of the hose (don't use a stream/jet of water, but a slow flowing 'soak') followed by a Megs Water Magnet towel is more than sufficient. Link to comment Share on other sites More sharing options...
Soapsuds Posted March 28, 2006 Report Share Posted March 28, 2006 I use a blade - also make sure there is not grit present wih a blody good rinse..... i use Megs shampoo, so it beads off very well. Also, i have a light metalic blue audi and if it did scratch it would be very tricky to see - might be different on a flat black car.... Mind, i have used on my starion with flat red paint and i hasnt damaged it yet Link to comment Share on other sites More sharing options...
Drewcam Posted March 28, 2006 Report Share Posted March 28, 2006 I use one on my flat red Audi. I have noticed a couple of Very faint straight line marks behind the rear door. The only explaination was the aquablade. I just make sure car is washed twice and rinsed thourghly with a hose now, and wipe the blade clean after every swipe. Works for me Link to comment Share on other sites More sharing options...
Korkster Posted March 28, 2006 Author Report Share Posted March 28, 2006 Hmmmm, cheers guys! On a Phantom Black - I think....I may just give it a miss! Link to comment Share on other sites More sharing options...
drpellypo Posted March 28, 2006 Report Share Posted March 28, 2006 Megs magnet for me. Wouldn't touch a blade with a barge pole. Link to comment Share on other sites More sharing options...
cabby Posted March 29, 2006 Report Share Posted March 29, 2006 I've used one once and managed to create a couple of scratches even after washing/risning thoroughly. Needless to say it has has not been used since. Link to comment Share on other sites More sharing options...
Si_GTi Posted March 29, 2006 Report Share Posted March 29, 2006 I'm using the Autoglym hydra blade and have been for a few washes now. So far, so good, with no scratching. I do give the car a thorough rinse after washing, and have a chamois on hand when using the blade to wipe the excess droplets off the blade, and to dry those harder-to-reach areas (or tricky small bits) that the blade can't handle. The blade saves a good few minutes IMO, and as I say so far no problems. Autoglym have just introduced a newer design of hydra blade, my bro in law reckons its not as good as the older design like mine? Older one has a blue grip/handle, newer one is a more contoured red grip (useful to know if/when you go shopping for one?). My Polo is Diamond Black pearlescent btw Link to comment Share on other sites More sharing options...
Korkster Posted March 29, 2006 Author Report Share Posted March 29, 2006 The New AG Blade was £15.99 in Halfrauds and there own brand approx £5ish - they were the only 2 they had in at last weekend, so there must be some big difference in the two then Link to comment Share on other sites More sharing options...
P_G Posted April 4, 2006 Report Share Posted April 4, 2006 I use the turtle wax blade and haven't scratched the car yet (touching wood as I say that) and it's brilliant black You have to use light stroke motions anyway, using it heavily just streaks the water. Every other stroke I wipe the blade clean with my AG Aqua Dry just in case. Great for the mornings after the rain as well as it gets rid of rain water bead marks as well. Turtle Wax one was only £8 I think? Link to comment Share on other sites More sharing options...
Drewcam Posted April 4, 2006 Report Share Posted April 4, 2006 Mine is the turtle wax one also Link to comment Share on other sites More sharing options...
