G8AMB Posted July 27, 2006 Report Share Posted July 27, 2006 Has anyone out there got a BMW bluetooth kit which they use with two phones? I am about to order a new one and was wondering if I am better off using an after market bluetooth kit (such as the Parrot). I have two phones (one for work and one for personal calls). I want to be able to easily swap between phones - I am not expecting to be able to use them at the same time. But do not want to go through too much hassle to swap between them. In my last car I had a sony ericson HCB-30 kit and although it could pair with up to 5 phones - it only really worked properly with the last paired phone - which was a bit of a hassle. Anybody swap phones regularily on a BMW bluetooth kit. I am not planning to but the sat nav unit - if that makes any difference? Link to comment Share on other sites More sharing options...
billy2shots Posted July 27, 2006 Report Share Posted July 27, 2006 Does work with two phones. You go to a menu and scroll down to the phone you want to connect with. May also connect anyway if it recognises which one you have that day. Link to comment Share on other sites More sharing options...
PeterS Posted July 27, 2006 Report Share Posted July 27, 2006 I have 2 phones paired in the 535d, and have no problems receiving calls on either 'phone. As mentioned above, making calls is just a matter of selecting the 'phone you want to use via I-Drive. If you don't have professional nav in the car, I guess you select through the stereo Peter Link to comment Share on other sites More sharing options...
encee Posted July 29, 2006 Report Share Posted July 29, 2006 I don`t have Nav at all, mate, in my 330d, but I find the Bluetooth excellent. I`ve not tried to use it with more than one phone though, so I can`t help you there. One thing I can tell you is that when you first look at the manual, it tells you which phones the Beemer will connect with, but don`t believe this as gospel, without trying yours first. Mine wasn`t listed as being compatible, but it works a treat (Samsung D500). Link to comment Share on other sites More sharing options...
Snail Posted August 1, 2006 Report Share Posted August 1, 2006 BMW Bluetooth seems to run fine with multiple paired phones, but it will only work with one at a time (obviously) and seems to prioritise them in pairing order (first paired, first chosen) Link to comment Share on other sites More sharing options...
rjb2k Posted August 29, 2006 Report Share Posted August 29, 2006 What is the cost of getting blue tooth operational on a 2002 330d. I have two phones as well but have all incoming work calls transferred to my personal phone. Basically because I use my work phone for sat nav but it saves two phones ringing at the same time, looking like some 80's yuppie. Link to comment Share on other sites More sharing options...
